EPiServer 11 Upgrade StructureMap Issue?
Hello,
We are in the process of updating to EPiServer 11 and have ran into an issue after updating the database.  I originally thought that this might be related to EPiServer Find (I have a post open there too), but looking at the error logs more I believe it may be related to StructureMap and EPiServer.Framework.
We are on versions EPiServer CMS 11.5.0, EPiServer Commerce 11.8.3, and EPiServer Find 12.7.1, EPiServer Find Commerce 10.1.2, EPiServer.ServiceLocation.StructureMap 2.0.1.0, StructureMap 4.6.1.0, and StructureMap.Web 1.0.0.0 (from the structuremap.web.4.0.0.315 folder).
Below are the errors and part of EPiServerFramework.config that I believe are related.
Error when trying to load the site after database upgrade:
Unable to load one or more of the requested types. Retrieve the LoaderExceptions property for more information.
Exception Details: System.Reflection.ReflectionTypeLoadException: Unable to load one or more of the requested types. Retrieve the LoaderExceptions property for more information.
Source Error:
[No relevant source lines]
Source File: c:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\26afe35f\1bf18c55\App_global.asax.0.cs    Line: 0
Stack Trace:
[ReflectionTypeLoadException: Unable to load one or more of the requested types. Retrieve the LoaderExceptions property for more information.]
   System.Reflection.RuntimeModule.GetTypes(RuntimeModule module) +0
   System.Reflection.Assembly.GetTypes() +112
   EPiServer.Find.ClientConventions.<>c__DisplayClass17_0.b__1(Assembly a) +30
   EPiServer.Find.Helpers.ListExtensions.ForEach(IEnumerable`1 value, Action`1 action) +153
   EPiServer.Find.ClientConventions.NestedConventions.MarkAllImplementationsAsNested(Type declaringType, String name) +352
   EPiServer.Find.Commerce.CatalogContentClientConventions.ApplyNestedConventions(NestedConventions nestedConventions) +298
   EPiServer.Find.Commerce.CatalogContentClientConventions.ApplyConventions(IClientConventions clientConventions) +181
   EPiServer.Find.Commerce.FindCommerceInitializationModule.Initialize(InitializationEngine context) +178
   EPiServer.Framework.Initialization.Internal.ModuleNode.Execute(Action a, String key) +55
   EPiServer.Framework.Initialization.Internal.ModuleNode.Initialize(InitializationEngine context) +123
   EPiServer.Framework.Initialization.InitializationEngine.InitializeModules() +248
[InitializationException: Initialize action failed for Initialize on class EPiServer.Find.Commerce.FindCommerceInitializationModule, EPiServer.Find.Commerce, Version=10.1.2.0, Culture=neutral, PublicKeyToken=8fe83dea738b45b7]
   EPiServer.Framework.Initialization.InitializationEngine.InitializeModules() +834
   EPiServer.Framework.Initialization.InitializationEngine.ExecuteTransition(Boolean continueTransitions) +198
   EPiServer.Framework.Initialization.InitializationModule.EngineExecute(HostType hostType, Action`1 engineAction) +876
   EPiServer.Framework.Initialization.InitializationModule.FrameworkInitialization(HostType hostType) +225
   EPiServer.Global..ctor() +103
   ASP.global_asax..ctor() in c:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\26afe35f\1bf18c55\App_global.asax.0.cs:0
   System.RuntimeTypeHandle.CreateInstance(RuntimeType type, Boolean publicOnly, Boolean noCheck, Boolean& canBeCached, RuntimeMethodHandleInternal& ctor, Boolean& bNeedSecurityCheck) +0
   System.RuntimeType.CreateInstanceSlow(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache, StackCrawlMark& stackMark) +142
   System.Activator.CreateInstance(Type type, Boolean nonPublic) +105
   System.RuntimeType.CreateInstanceImpl(BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes, StackCrawlMark& stackMark) +1515
   System.Activator.CreateInstance(Type type, BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes) +186
   System.Activator.CreateInstance(Type type, BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture) +27
   System.Web.HttpRuntime.CreateNonPublicInstance(Type type, Object[] args) +79
   System.Web.HttpApplicationFactory.GetSpecialApplicationInstance(IntPtr appContext, HttpContext context) +281
   System.Web.Hosting.PipelineRuntime.InitializeApplication(IntPtr appContext) +329
   System.Web.HttpRuntime.FirstRequestInit(HttpContext context) +525
   System.Web.HttpRuntime.EnsureFirstRequestInit(HttpContext context) +118
   System.Web.HttpRuntime.ProcessRequestNotificationPrivate(IIS7WorkerRequest wr, HttpContext context) +708
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.7.2558.0
Log Error:
2018-03-29 10:54:52,419 [1] ERROR EPiServer.Framework.Initialization.InitializationEngine: Initialize action failed for 'Initialize on class EPiServer.Find.Commerce.FindCommerceInitializationModule, EPiServer.Find.Commerce, Version=10.1.2.0, Culture=neutral, PublicKeyToken=8fe83dea738b45b7'
   at System.Reflection.RuntimeModule.GetTypes(RuntimeModule module)
   at System.Reflection.Assembly.GetTypes()
   at EPiServer.Find.ClientConventions.NestedConventions.<>c__DisplayClass17_0.b__1(Assembly a)
   at EPiServer.Find.Helpers.ListExtensions.ForEach[T](IEnumerable`1 value, Action`1 action)
   at EPiServer.Find.ClientConventions.NestedConventions.MarkAllImplementationsAsNested(Type declaringType, String name)
   at EPiServer.Find.Commerce.CatalogContentClientConventions.ApplyNestedConventions(NestedConventions nestedConventions)
   at EPiServer.Find.Commerce.CatalogContentClientConventions.ApplyConventions(IClientConventions clientConventions)
   at EPiServer.Find.Commerce.FindCommerceInitializationModule.Initialize(InitializationEngine context)
   at EPiServer.Framework.Initialization.Internal.ModuleNode.Execute(Action a, String key)
   at EPiServer.Framework.Initialization.Internal.ModuleNode.Initialize(InitializationEngine context)
   at EPiServer.Framework.Initialization.InitializationEngine.InitializeModules()
2018-03-29 10:55:02,432 [10] WARN EPiServer.Framework.Initialization.Internal.ShutdownTracker: ASP.NET shutting down due to InitializationError
2018-03-29 10:57:38,802 [15] INFO EPiServer.Framework.Internal.ActivatorUtilities: Failed to retrieve type 'EPiServer.Framework.Localization.XmlResources.FileXmlLocalizationProvider' from container container. Attempting to use default constructor.
EPiServer.ServiceLocation.ActivationException: Activation error occurred while trying to get instance of type FileXmlLocalizationProvider, key "" ---> StructureMap.StructureMapConfigurationException: No default Instance is registered and cannot be automatically determined for type 'EPiServer.Framework.FileSystem.IFileSystemWatcher'
There is no configuration specified for EPiServer.Framework.FileSystem.IFileSystemWatcher
1.) new FileXmlLocalizationProvider(*Default of VirtualPathProvider*, *Default of IFileSystemWatcher*, *Default of IHostingEnvironment*)
2.) EPiServer.Framework.Localization.XmlResources.FileXmlLocalizationProvider
3.) Instance of EPiServer.Framework.Localization.XmlResources.FileXmlLocalizationProvider
4.) Container.GetInstance(EPiServer.Framework.Localization.XmlResources.FileXmlLocalizationProvider)
   at lambda_method(Closure , IBuildSession , IContext )
   at StructureMap.Building.BuildPlan.Build(IBuildSession session, IContext context)
   at StructureMap.SessionCache.GetObject(Type pluginType, Instance instance, ILifecycle lifecycle)
   at StructureMap.SessionCache.GetDefault(Type pluginType, IPipelineGraph pipelineGraph)
   at StructureMap.Container.GetInstance(Type pluginType)
   at EPiServer.ServiceLocation.ServiceLocatorImplBase.GetInstance(Type serviceType, String key)
   at EPiServer.Framework.Internal.ActivatorUtilities.GetServiceOrCreateInstance(IServiceLocator locator, Type type)
The section in our EPiServerFramework.config file that I believe is causing the issue.
Thank you,
Kevin Larsen
#190051
Mar 29, 2018 18:56
hmm interesting. file watchers are initialized manually in XML provider itself (at least in 11.3).
one trick would be to *explicitly* register implementation in IoC contsiner (for now).
#190060
Mar 30, 2018 21:21
Hi, I would say it is not about the FileXmlLocalizationProvider. The message is information that there is no implementation registered in the container and it is using the default implementation with default constructor instead. You can check this same behavior with Alloy site, for example with EPiServer.CMS version 11.3.4 and with the latest.
Your problem is the Find commerce module: EPiServer.Find.Commerce.FindCommerceInitializationModule. What if you add more info or debug logging from the EPiServer.Find.Commerce namespace to be able to see that way what might go wrong (guess from the log messages)? Are you absolutely sure that you have the correct dlls in bin folder after the upgrade?
#190064
Mar 31, 2018 9:09
from exception (haven't tried myself this combination) you can see that find module asks for types and creates instance of target type via SM and falls into XML provider constructor that requires file watcher as well to be specified. this is SM default constructor seelction policy - to try to use the most specific (with most arguments) constructor. this is interesting. might be worth trying out in sample project.
#190065
Mar 31, 2018 9:34
Another developer on the project...  The error is happening right after the code calls
Because of that we can't step in (in Visual Studio) to see where the code is failing to load the types.  This isn't part of our custom code.
All dlls are up to date - believe me we have checked.  Over and over.
#190104
Apr 02, 2018 16:00
just out of curiosity, what happens when you explicitly add file watcher to the IoC container? VS will not break (it's probably too early in the pipeline)..
#190109
Apr 02, 2018 16:31
Do you have an example of how we could do that?  What's happening seems to be inside a Nuget package...
Susan
#190157
Apr 03, 2018 19:39
I get the same error, did you find a solution?
#194427
Jun 21, 2018 8:09
https://world.episerver.com/forum/developer-forum/EPiServer-Search/Thread-Container/2018/3/episerver.find.commerce-10.1.2-unable-to-load-one-or-more-of-the-requested-types/?pageIndex=2
You can take a look here, so basically make sure you clean bin folder and there is no configuration transformation that messes up the versions
#194431
Jun 21, 2018 9:21
I have the same issue upgrading from cms 10 / commerce 11 to cms 11.9.0 and commerce 12.3.1 (latest versions). I do not get the Find related exceptions but does show the error for the IFileSystemWatcher. see log below
I tried a clean install of the epi versions mentioned, but that is working correclty.
2018-06-21 16:43:46,118 [1] INFO EPiServer.Framework.Internal.ActivatorUtilities: Failed to retrieve type 'EPiServer.Framework.Localization.XmlResources.FileXmlLocalizationProvider' from container container. Attempting to use default constructor.
2018-06-21 16:43:47,472 [1] INFO EPiServer.Framework.Internal.ActivatorUtilities: Failed to retrieve type 'EPiServer.Azure.Events.AzureEventProvider' from container container. Attempting to use default constructor.
EPiServer.ServiceLocation.ActivationException: Activation error occurred while trying to get instance of type AzureEventProvider, key "" ---> StructureMap.StructureMapConfigurationException: No default Instance is registered and cannot be automatically determined for type 'EPiServer.Azure.Events.Internal.IServiceBusSetup'
There is no configuration specified for EPiServer.Azure.Events.Internal.IServiceBusSetup
1.) new AzureEventProvider(*Default of AzureEventClientFactory*, *Default of EventsServiceKnownTypesLookup*, *Default of IServiceBusSetup*)
2.) EPiServer.Azure.Events.AzureEventProvider
3.) Instance of EPiServer.Azure.Events.AzureEventProvider
4.) Container.GetInstance(EPiServer.Azure.Events.AzureEventProvider)
2018-06-21 16:43:47,954 [1] INFO EPiServer.Shell.Modules.ModuleFinder: Looking for module in '~/EPiServer/DbLocalizationProvider.AdminUI.EPiServer'
2018-06-21 16:43:47,982 [1] INFO EPiServer.Shell.Modules.ModuleFinder: Reading manifest from: /EPiServer/DbLocalizationProvider.AdminUI.EPiServer/module.config
2018-06-21 16:43:48,102 [1] INFO EPiServer.Shell.Modules.ModuleFinder: Found module: [ShellModule Name='DbLocalizationProvider.AdminUI.EPiServer' RouteBasePath='EPiServer/' ResourceBasePath='/EPiServer/DbLocalizationProvider.AdminUI.EPiServer/' ClientResourcePath='/EPiServer/DbLocalizationProvider.AdminUI.EPiServer/' Assemblies=[DbLocalizationProvider.AdminUI.EPiServer] Controllers=undefined]
2018-06-21 16:43:48,107 [1] INFO EPiServer.Shell.Modules.ModuleFinder: Looking for module in '~/EPiServer/Find'
2018-06-21 16:43:48,114 [1] INFO EPiServer.Shell.Modules.ModuleFinder: Reading manifest from: /EPiServer/Find/module.config
2018-06-21 16:43:48,184 [1] INFO EPiServer.Shell.Modules.ModuleFinder: Found module: [ShellModule Name='Find' RouteBasePath='EPiServer/' ResourceBasePath='/EPiServer/Find/' ClientResourcePath='/EPiServer/Find/' Assemblies=[EPiServer.Find.UI, EPiServer.Find.Blocks, EPiServer.Find.Cms, EPiServer.Find.Framework] Controllers=undefined]
2018-06-21 16:43:48,188 [1] INFO EPiServer.Shell.Modules.ModuleFinder: Looking for module in '~/EPiServer/EPiServer.Labs.LanguageManager'
2018-06-21 16:43:48,194 [1] INFO EPiServer.Shell.Modules.ModuleFinder: Reading manifest from: /EPiServer/EPiServer.Labs.LanguageManager/module.config
2018-06-21 16:43:48,213 [1] INFO EPiServer.Shell.Modules.ModuleFinder: Found module: [ShellModule Name='EPiServer.Labs.LanguageManager' RouteBasePath='EPiServer/' ResourceBasePath='/EPiServer/EPiServer.Labs.LanguageManager/' ClientResourcePath='/EPiServer/EPiServer.Labs.LanguageManager/3.1.4/' Assemblies=[EPiServer.Labs.LanguageManager] Controllers=undefined]
2018-06-21 16:43:48,218 [1] INFO EPiServer.Shell.Modules.ModuleFinder: Looking for module in '~/EPiServer/EPiServer.Packaging.UI'
2018-06-21 16:43:48,230 [1] INFO EPiServer.Shell.Modules.ModuleFinder: Reading manifest from: /EPiServer/EPiServer.Packaging.UI/module.config
2018-06-21 16:43:48,255 [1] INFO EPiServer.Shell.Modules.ModuleFinder: Found module: [ShellModule Name='EPiServer.Packaging.UI' RouteBasePath='EPiServer/' ResourceBasePath='/EPiServer/EPiServer.Packaging.UI/' ClientResourcePath='/EPiServer/EPiServer.Packaging.UI/3.4.0.0/' Assemblies=[EPiServer.Packaging, EPiServer.Packaging.UI] Controllers=undefined]
2018-06-21 16:43:48,259 [1] INFO EPiServer.Shell.Modules.ModuleFinder: Looking for module in '~/EPiServer/EPiServer.Forms.UI'
2018-06-21 16:43:48,271 [1] INFO EPiServer.Shell.Modules.ModuleFinder: Reading manifest from: /EPiServer/EPiServer.Forms.UI/module.config
2018-06-21 16:43:48,298 [1] INFO EPiServer.Shell.Modules.ModuleFinder: Found module: [ShellModule Name='EPiServer.Forms.UI' RouteBasePath='EPiServer/' ResourceBasePath='/EPiServer/EPiServer.Forms.UI/' ClientResourcePath='/EPiServer/EPiServer.Forms.UI/4.14.0/' Assemblies=[EPiServer.Forms.UI, EPiServer.Forms.Core] Controllers=undefined]
2018-06-21 16:43:48,303 [1] INFO EPiServer.Shell.Modules.ModuleFinder: Looking for module in '~/EPiServer/EPiServer.Forms'
2018-06-21 16:43:48,313 [1] INFO EPiServer.Shell.Modules.ModuleFinder: Reading manifest from: /EPiServer/EPiServer.Forms/module.config
2018-06-21 16:43:48,326 [1] INFO EPiServer.Shell.Modules.ModuleFinder: Found module: [ShellModule Name='EPiServer.Forms' RouteBasePath='EPiServer/' ResourceBasePath='/EPiServer/EPiServer.Forms/' ClientResourcePath='/EPiServer/EPiServer.Forms/4.14.0/' Assemblies=[EPiServer.Forms] Controllers=undefined]
2018-06-21 16:43:48,333 [1] INFO EPiServer.Shell.Modules.ModuleFinder: Looking for module in '~/EPiServer/Commerce'
2018-06-21 16:43:48,343 [1] INFO EPiServer.Shell.Modules.ModuleFinder: Reading manifest from: /EPiServer/Commerce/module.config
2018-06-21 16:43:48,369 [1] INFO EPiServer.Shell.Modules.ModuleFinder: Found module: [ShellModule Name='Commerce' RouteBasePath='EPiServer/' ResourceBasePath='/EPiServer/Commerce/' ClientResourcePath='/EPiServer/Commerce/12.3.1.0/' Assemblies=[EPiServer.Business.Commerce, EPiServer.Commerce.UI] Controllers=undefined]
2018-06-21 16:43:48,374 [1] INFO EPiServer.Shell.Modules.ModuleFinder: Looking for module in '~/EPiServer/EPiServer.Commerce.Shell'
2018-06-21 16:43:48,388 [1] INFO EPiServer.Shell.Modules.ModuleFinder: Reading manifest from: /EPiServer/EPiServer.Commerce.Shell/module.config
2018-06-21 16:43:48,404 [1] INFO EPiServer.Shell.Modules.ModuleFinder: Found module: [ShellModule Name='EPiServer.Commerce.Shell' RouteBasePath='EPiServer/' ResourceBasePath='/EPiServer/EPiServer.Commerce.Shell/' ClientResourcePath='/EPiServer/EPiServer.Commerce.Shell/12.3.1.0/' Assemblies=[EPiServer.Commerce.Shell] Controllers=undefined]
2018-06-21 16:43:48,409 [1] INFO EPiServer.Shell.Modules.ModuleFinder: Looking for module in '~/EPiServer/EPiServer.Commerce.UI.CustomerService'
2018-06-21 16:43:48,420 [1] INFO EPiServer.Shell.Modules.ModuleFinder: Reading manifest from: /EPiServer/EPiServer.Commerce.UI.CustomerService/module.config
2018-06-21 16:43:48,436 [1] INFO EPiServer.Shell.Modules.ModuleFinder: Found module: [ShellModule Name='EPiServer.Commerce.UI.CustomerService' RouteBasePath='EPiServer/' ResourceBasePath='/EPiServer/EPiServer.Commerce.UI.CustomerService/' ClientResourcePath='/EPiServer/EPiServer.Commerce.UI.CustomerService/12.3.1.0/' Assemblies=[EPiServer.Commerce.UI.CustomerService] Controllers=undefined]
2018-06-21 16:43:48,441 [1] INFO EPiServer.Shell.Modules.ModuleFinder: Looking for module in '~/EPiServer/EPiServer.Commerce.Shell.ManagerIntegration'
2018-06-21 16:43:48,452 [1] INFO EPiServer.Shell.Modules.ModuleFinder: Reading manifest from: /EPiServer/EPiServer.Commerce.Shell.ManagerIntegration/module.config
2018-06-21 16:43:48,468 [1] INFO EPiServer.Shell.Modules.ModuleFinder: Found module: [ShellModule Name='EPiServer.Commerce.Shell.ManagerIntegration' RouteBasePath='EPiServer/' ResourceBasePath='/EPiServer/EPiServer.Commerce.Shell.ManagerIntegration/' ClientResourcePath='/EPiServer/EPiServer.Commerce.Shell.ManagerIntegration/12.3.1.0/' Assemblies=[EPiServer.Commerce.Shell.ManagerIntegration] Controllers=undefined]
2018-06-21 16:43:48,474 [1] INFO EPiServer.Shell.Modules.ModuleFinder: Looking for module in '~/EPiServer/EPiServer.Cms.TinyMce'
2018-06-21 16:43:48,485 [1] INFO EPiServer.Shell.Modules.ModuleFinder: Reading manifest from: /EPiServer/EPiServer.Cms.TinyMce/module.config
2018-06-21 16:43:48,500 [1] INFO EPiServer.Shell.Modules.ModuleFinder: Found module: [ShellModule Name='EPiServer.Cms.TinyMce' RouteBasePath='EPiServer/' ResourceBasePath='/EPiServer/EPiServer.Cms.TinyMce/' ClientResourcePath='/EPiServer/EPiServer.Cms.TinyMce/2.4.0/' Assemblies=[EPiServer.Cms.TinyMce] Controllers=undefined]
2018-06-21 16:43:48,505 [1] INFO EPiServer.Shell.Modules.ModuleFinder: Looking for module in '~/EPiServer/LanguageWire.Connector'
2018-06-21 16:43:48,510 [1] INFO EPiServer.Shell.Modules.ModuleFinder: Reading manifest from: /EPiServer/LanguageWire.Connector/module.config
2018-06-21 16:43:48,524 [1] INFO EPiServer.Shell.Modules.ModuleFinder: Found module: [ShellModule Name='LanguageWire.Connector' RouteBasePath='EPiServer/' ResourceBasePath='/EPiServer/LanguageWire.Connector/' ClientResourcePath='/EPiServer/LanguageWire.Connector/ClientResources/' Assemblies=[LanguageWire.Connectors.EpiServer] Controllers=undefined]
2018-06-21 16:43:48,530 [1] INFO EPiServer.Shell.Modules.ModuleFinder: Looking for module in '~/EPiServer/Shell'
Any thoughts?
cheers,
Pierre
#194465
Edited, Jun 21, 2018 16:54
can you paste fragment of <localization> element under <episerver.framework>?
#194591
Jun 26, 2018 10:11
Hi Valdis,
Thanks for your reply,
The <Localization> section is already under <epsierver.framework>.
thnx
Pierre
#194593
Jun 26, 2018 10:44
sorry for my lazyness in writing, but can you paste content of that element?
#194596
Jun 26, 2018 10:51
I do have an update on this issue.
I created an episerver support ticket. After some forth and back emailing details and config settings, Episerver was able to reproduce this issue.
So they created a bug for it and hoping to fix it shortly. I haven't heard anything about it since yesterday. I expect some response this week.
cheers
#194597
Jun 26, 2018 10:52
Hi Valdis,
Sure, the content of the localization section looks like this:
<episerver.framework updateDatabaseSchema="true" createDatabaseSchema="true">
<localization fallbackBehavior="FallbackCulture, MissingMessage, Echo" fallbackCulture="en">
<providers>
<add name="db" type="DbLocalizationProvider.EPiServer.DatabaseLocalizationProvider, DbLocalizationProvider.EPiServer" />
<add virtualPath="~/Resources/LanguageFiles" name="languageFiles" type="EPiServer.Framework.Localization.XmlResources.FileXmlLocalizationProvider, EPiServer.Framework.AspNet" />
</providers>
</localization>
cheers,
Pierre
#194599
Jun 26, 2018 10:54
ok, so what was the root casue in configuration when they could repo the issue?
#194600
Jun 26, 2018 11:10
Not sure, they didn't say,
A clean install of CMS 11 and Commerce 12 does not reproduce the issue. Episerver and I tested it.
Only when upgrading from CMS 10 / Commerce 11 to CMS 11 and Commerce 12 the issue was reproduced. So I guess there is some configuration transformation not done correctly during the upgrade, or something else is interfering with code that handles the dependency injection for the types that are missing. The interfaces in question are moved from to a different assembly, episerver.framework.aspnet. Maybe the structuremap scanning does not include this new assembly or something..
Guess we'll know as soon as Episerver finds a cause.
I'll keep this issues updated.
cheers,
#194601
Jun 26, 2018 11:19
EpiServer investigated the issue and reported it as a bug.
https://world.episerver.com/support/Bug-list/bug/CMS-11111
Cheers,
Pierre
#194678
Jun 28, 2018 6:56
