Hi what is your requirement? They may be other approaches which can solve your need, for example you could consider using a content event to hook onto the ContentLoading event.
We have this:
[VisitorGroupCriterion(Category = "Member", DisplayName = "Member role", Description = "")]
public class UserRoleCriterion : CriterionBase<UserRoleModel>
public override bool IsMatch(IPrincipal principal, HttpContextBase httpContext)
if (httpContext?.Session == null)
return httpContext.Handler is ContentMediaHttpHandler;
if (SessionHelper.Current == null)
return false;
var userRoles = SessionHelper.Current.UserRoles;
return userRoles != null && userRoles.Any() && userRoles.Any(r => r.Name == Model.Condition);
public class UserRoleModel : CriterionModelBase
[Required, DojoWidget(SelectionFactoryType = typeof(RolesSelectionFactory))]
public string Condition { get; set; }
public override ICriterionModel Copy()
return ShallowCopy();
But when loading files the contex is ContentMediaHttpHandler, and it has no session.
If only I can override the handler with my own, it will work. I works fine with IRenderTemplate<IContentImage> but not with IRenderTemplate<IContentMedia>
Is your specific requirement to vary the viewing of an image depending on whether someone is in a role or not?
The requirement is to restrict pages, media files (images and documents) to VisitorGroups, and check our role session.
If only IRenderTemplate<IContentMedia> would work...
My solution to change ContentMediaHttpHandler to custom handler:
public class HandlerInitialization : IInitializableModule
context.Locate.TemplateResolver().TemplateResolved += TemplateCoordinator.OnHandlerTemplateResolved;
ServiceLocator.Current.GetInstance<TemplateResolver>().TemplateResolved -= TemplateCoordinator.OnHandlerTemplateResolved;
Change Template:
public class TemplateCoordinator
public static void OnHandlerTemplateResolved(object sender, TemplateResolverEventArgs args)
if (args.SelectedTemplate == null ||
args.SelectedTemplate.TemplateType != typeof(ContentMediaHttpHandler))
return;
var mediaHandler = args.SupportedTemplates
.SingleOrDefault(r => r.Name.Contains("CustomContentMediaHttpHandler")
&& r.TemplateTypeCategory == args.SelectedTemplate.TemplateTypeCategory);
if (mediaHandler != null)
args.SelectedTemplate = mediaHandler;
Hello
I have a custom ContentMediaHttpHandler:
I need to extend it with IRequiredSessionState to check a saved session in a CriterionBase<>. >
But my handler doesnt run, only standard ContentMediaHttpHandler is running.
If I change to IRenderTemplate it will work for images, but not documents.
What is the problem?
