I want to use Boostrap table in an Episerver plugin (separate view).
If I add the following sample to a plain .aspx file (outside EPiserver) everything works as expected.
If I add the same code to an Episerver plugin I get the following console error:
The edit plugin loads the following Episerver components in head:
Any advice on how to get past this issue?
