I haven't done anything similar, but I don't see any problems with what you describe. Not sure what will happen if you have global assets with the same path and name, though.
Access rights per subtree works fine.
Hello!
We have platform project running for one of our customers using a singular code base that is deployed onto separate database instances, one per site (total of 15). This is undesirable for many reasons, and we are now looking into how one might merge these different instances into a single multi-site instance, with a single database.
My first instinct was to, on a new database, set up each site as you would normally. Then for each existing database import the respective site tree into the appropriate site using import/export data in the admin view.
Please share any thoughts or experiences you have.
Thanks in advance!
