Hi Erik,
Did you resolve this problem? And in that case what did you do? (we seem to have the same problem now)
regards
Magnus
<package id="EPiServer.Azure" version="9.4.4" targetFramework="net471" />
<package id="EPiServer.CMS.AspNet" version="11.11.3" targetFramework="net471" />
<package id="EPiServer.CMS.Core" version="11.11.3" targetFramework="net471" />
<package id="EPiServer.CMS.TinyMce" version="2.8.0" targetFramework="net471" />
<package id="EPiServer.CMS.UI" version="11.19.2" targetFramework="net472" />
<package id="EPiServer.CMS.UI.Core" version="11.19.2" targetFramework="net472" />
<package id="EPiServer.Find" version="13.0.5" targetFramework="net471" />
<package id="EPiServer.Find.Cms" version="13.0.5" targetFramework="net471" />
<package id="EPiServer.Find.Framework" version="13.0.5" targetFramework="net471" />
<package id="EPiServer.Framework" version="11.11.3" targetFramework="net471" />
<package id="EPiServer.Framework.AspNet" version="11.11.3" targetFramework="net471" />
<package id="EPiServer.ServiceLocation.StructureMap" version="2.0.1" targetFramework="net471" />
I just did a quick test modyfying and adding a WHERE 0 = 1 to the netNotificationSubscriptionListByKey procedure so that it returns 0 rows.
That reduces the netSynchedUserList calls to only 1 (from 119) when loading Edit Mode.
Have an open dev support ticket running as well...
There is now a Bug ticket created. The call is being made indirectly on Edit Mode load (where its not needed).
Will add more info when it arrives.
We are also starting to have some issues for some users not everyone yet<package id="EPiServer.CMS" version="11.12.0" targetFramework="net462" /><package id="EPiServer.CMS.AspNet" version="11.12.0" targetFramework="net462" /><package id="EPiServer.CMS.Core" version="11.12.0" targetFramework="net462" /><package id="EPiServer.CMS.TinyMce" version="2.8.0" targetFramework="net462" /><package id="EPiServer.CMS.UI" version="11.20.1" targetFramework="net462" /><package id="EPiServer.CMS.UI.Core" version="11.20.1" targetFramework="net462" /><package id="EPiServer.Forms" version="4.24.2" targetFramework="net462" /><package id="EPiServer.Forms.Core" version="4.24.2" targetFramework="net462" /><package id="EPiServer.Forms.UI" version="4.24.2" targetFramework="net462" /><package id="EPiServer.Framework" version="11.12.0" targetFramework="net462" /><package id="EPiServer.Framework.AspNet" version="11.12.0" targetFramework="net462" /><package id="EPiServer.Labs.LanguageManager" version="3.3.1" targetFramework="net462" /><package id="EPiServer.Logging.Log4Net" version="2.2.2" targetFramework="net462" /><package id="EPiServer.Marketing.KPI" version="2.5.2" targetFramework="net462" /><package id="EPiServer.Marketing.Messaging" version="1.3.0" targetFramework="net462" /><package id="EPiServer.Marketing.Testing" version="2.5.9" targetFramework="net462" /><package id="EPiServer.Packaging" version="3.4.0" targetFramework="net462" /><package id="EPiServer.Packaging.UI" version="3.4.0" targetFramework="net462" /><package id="EPiServer.Search" version="9.0.3" targetFramework="net462" /><package id="EPiServer.Search.Cms" version="9.0.3" targetFramework="net462" /><package id="EPiServer.ServiceLocation.StructureMap" version="2.0.1" targetFramework="net462" />
If my client was hosting with access to the db server I would do something similar to the WHERE 0 = 1 to the netNotificationSubscriptionListByKey SP hack right away. A bit more complicated to do a temporary quick fix with DXC-S...
We are hosting our own db so it can be done.
What are the tblNotificationSubscription used for? Is there a job that uses it somehow?
Do you have the Bug number?
We have around 500 editors on our site and for the ones that are last in the list it takes over 2 minutes to just enter epi edit mode.
We will do your fix tomorrow morning.
I think it's used by Projects, Edit Mode comments, Content Approvals and maybe something else. I guess also the product news feed.
It's not on the public bug list yet but when I find out it is I will post the link here.
Are you also running a auth setup that puts stuff in the tblSynched*-tables? I also noted that Epi should look into better indexing or possibly cache those calls as well as fixing the unnecessary indirect call.
ok.
What we have found out is this:
It runs: exec netNotificationSubscriptionListByKey @SubscriptionKey=N'feature://notification/',@SubscriptionKeyMatchMode=1
And gets a list of users, then it calls "synchedUser" for every user in the list until it finds the user who is trying to login, so if you are in the bottom of the list it makes a lot of calls, and it iterates the list with calls to "synchedUser" twice.
We haven't verified that this solves our issue yet, but looks like it should be fixed now in EPiServer.CMS.UI 11.22.1.
Bug - CMS-14762
Looks like they only addressed the unnecessary call when Edit Mode loads and not the overall slowness and shooting database queries individually from inside a loop.
I still see slow transactions with the same pattern in Application Insights.
I can confirm that upgrading the EPiServer.CMS.UI solved our issues with accessing edit mode at least, now taking <1s instead of ~1 min :)
Sometimes when trying to enter edit mode, it takes several minutes to load it even though no restart of the application has happened or anything. From what I have been able to find out so far, the longest time is spent in the database. Where some GET requests to Home/Index that is /episerver/cms takes as long as 2,5 minutes (where nearly 100% of it is spent in the database). Where it makes 1600 sql queries.
SELECT Id, ItemType FROM [dbo].[VW_EPiServer.Shell.Profile.ProfileData] WHERE [UserName] = @UserNameSELECT Id, ItemType,[UserName] FROM [dbo].[VW_EPiServer.Shell.Profile.ProfileData] WHERE [StoreId] = @StoreIdSELECT tblBigTableReference.ElementType, tblBigTableReference.ElementStoreName, tblBigTableReference.PropertyName, tblBigTableReference.RefIdValue, tblBigTableIdentity.Guid, tblBigTableReference.LongValue, tblBigTableReference.Type, tblBigTableReference.StringValue, tblBigTableReference.ExternalIdValue, tblBigTableReference.DecimalValue FROM [dbo].[tblBigTableReference] LEFT OUTER JOIN [dbo].[tblBigTableIdentity] ON tblBigTableReference.RefIdValue = tblBigTableIdentity.pkId WHERE tblBigTableReference.pkId= @Id AND (tblBigTableReference.Type = @Reference OR tblBigTableReference.Type = @Provider)SELECT c.name AS column_name,t.name AS type_name,c.max_length,c.precision,c.scale, CAST(CASE WHEN EXISTS(SELECT * FROM sys.index_columns AS i WHERE i.object_id=c.object_id AND i.column_id=c.column_id) THEN 1 ELSE 0 END AS BIT) AS column_indexed FROM sys.columns AS c JOIN sys.types AS t ON c.user_type_id=t.user_type_id WHERE c.object_id = OBJECT_ID('tblBigTableReference') ORDER BY c.column_id;SELECT CollectionType, ElementType, ElementStoreName, IsKey, [Index] Indexvalue, [BooleanValue], [IntegerValue], [LongValue], [DateTimeValue], [GuidValue], [FloatValue], [StringValue], [BinaryValue], [RefIdValue], [ExternalIdValue], [DecimalValue], tblBigTableIdentity.Guid FROM [dbo].[tblBigTableReference] LEFT OUTER JOIN [dbo].[tblBigTableIdentity] ON tblBigTableReference.RefIdValue = tblBigTableIdentity.pkId WHERE tblBigTableReference.pkId = @pkId AND PropertyName=@PropertyName ORDER BY [Index] ASC, IsKey DESCSELECT TOP(1) "EPiServer.Shell.Storage.PersonalizedViewSettingsStorage".Id, "EPiServer.Shell.Storage.PersonalizedViewSettingsStorage".ItemType, "EPiServer.Shell.Storage.PersonalizedViewSettingsStorage"."UserName", "EPiServer.Shell.Storage.PersonalizedViewSettingsStorage"."ViewName" FROM [dbo].[VW_EPiServer.Shell.Storage.PersonalizedViewSettingsStorage] as "EPiServer.Shell.Storage.PersonalizedViewSettingsStorage" WHERE ("EPiServer.Shell.Storage.PersonalizedViewSettingsStorage".[UserName] = @Param0 AND "EPiServer.Shell.Storage.PersonalizedViewSettingsStorage".[ViewName] = @Param1)netNotificationSubscriptionListByKeySELECT [Limit1].[UserId] AS [UserId], [Limit1].[PropertyNames] AS [PropertyNames], [Limit1].[PropertyValueStrings] AS [PropertyValueStrings], [Limit1].[PropertyValueBinary] AS [PropertyValueBinary], [Limit1].[LastUpdatedDate] AS [LastUpdatedDate] FROM ( SELECT TOP (1) [Extent1].[UserId] AS [UserId], [Extent1].[PropertyNames] AS [PropertyNames], [Extent1].[PropertyValueStrings] AS [PropertyValueStrings], [Extent1].[PropertyValueBinary] AS [PropertyValueBinary], [Extent1].[LastUpdatedDate] AS [LastUpdatedDate] FROM [dbo].[Profiles] AS [Extent1] INNER JOIN [dbo].[Users] AS [Extent2] ON [Extent1].[UserId] = [Extent2].[UserId] INNER JOIN [dbo].[Applications] AS [Extent3] ON [Extent2].[ApplicationId] = [Extent3].[ApplicationId] WHERE (((LOWER([Extent3].[ApplicationName])) = (LOWER(@p__linq__0))) OR ((LOWER([Extent3].[ApplicationName]) IS NULL) AND (LOWER(@p__linq__0) IS NULL))) AND (((LOWER([Extent2].[UserName])) = (LOWER(@p__linq__1))) OR ((LOWER([Extent2].[UserName]) IS NULL) AND (LOWER(@p__linq__1) IS NULL))) ) AS [Limit1]netSynchedUserListWhere it keeps re-iterating between the last two for the remaining 1580 queries, i'm assuming by iterating through all users or something. Does anyone recognize this problem? It is currently not a very good way for the editors to work if the site takes 2+ minutes to load sometimes.
Br,
Erik
