If you mean the "Required properties" dialog—that has been in place since CMS 7 🙂
Probably the easiest solution is just to create your own ValidationAttribute and use that, if you look at the RequiredAttribute (System.ComponentModel.DataAnnotations) what it does is extremely simple, as an advantage you can also customize and localize the validation message.
Hi Jiri, if you just want to hide required properties on the create content view then have a look at this post by David: Hiding required properties on the create new page in Episerver
That blog post from David is really intesting, pretty cool solution.
@Jake Jones: You’re right. The Additional properties dialog confused me. I was not seeing it in previous versions.
@Antti Alasvuo: Thanks for link. This solution is sufficient.
Hi again,
@Antti Alasvuo: I noticed there is issue with this solution. Check with last comment in disucssion. I cannot remove answer mark due some failure.
I edit my question to reflect the state.
Hi Jiri,
If that's the case, wouldn't it be just as easy to create your own RequiredAttribute? Or use IValidate<T> (David's blog post mentions this under "Other approaches")?
Hi Jake,
custom requiered attribute is solution to this but only in case the block is not created via content area – additional properties get validated upon creation. So functionally the solutions are equal. IValidate is not in any case because (as David noted) it is time and space consuptive.
I tried to skip validation via IContentEvents.CreatingContent but it to late to change SaveAction to skip validation (SaveAction.SkipValidation) in event args.
Is there some work around how to instruct CMS to skip validation on content creations?
Hi Jiri, you could try again remove the "accept answer" if was just a glitch in the system OR ask support to remove it OR if some of the moderators pick up this chain they can remove the answer (maybe).
Also comment on the linked blog posts comment, David answered you there (and you answered to that), so for others: this behavior might be by design.
I still think that perhaps you should re-evaluate your requirement to not show dialogs for required properties (if this is only for testers). Easiest solution is to educate/train the users how the 'create new block' works.
I'm not sure if you know also the difference of clicking the 'create a new block' link in content area VS 'new block' in the assets pane? So here goes just in case this is unclear:
(so the above is related to Davids comment on 'by design behavior').
So here is one hackish solution to work aroud not showing "dialogs" during creating a block.
Sample model:
[ContentType(DisplayName = "DemoRequiredPropertiesBlock", GUID = "2b2358a0-ce5e-4e5c-ad99-2b89227d3572", Description = "")]
public class DemoRequiredPropertiesBlock : BlockData
DisplayName = $"DefaultDisplayName-{DateTime.Now.Ticks}";
SomeNumber = new Random().Next(1, 99999);
[Required]
[CultureSpecific]
[Display(Name = "DisplayName", Description = "DisplayName field's description", GroupName = SystemTabNames.Content, Order = 1)]
public virtual string DisplayName { get; set; }
[Required]
[Display(Name = "SomeNumber", Description = "SomeNumber field's description", GroupName = SystemTabNames.Content, Order = 2)]
public virtual int SomeNumber { get; set; }
[CultureSpecific]
[Display(Name = "SomeText", Description = "SomeText field's description", GroupName = SystemTabNames.Content, Order = 3)]
public virtual string SomeText { get; set; }
Now when you create that block only name for the block is required to be entered.
Not exactly what you are looking for but I think the answer is that it can not be achieved fully what you want.
Starting with some of the new CMS version (guessing some 11 version) there is new creation dialog upon content item creation.
I want to get rid of Required properties dialog upon new page and block creation (via Blocks gadget).
This has some disadvantages:
Due reasons:
I wonder how to skip initial creation dialog on per content type basis. Also some general switch off could be interesting for me.
There is one more creation dialog type. Dialog for new block created via content area. There is always some dialog:
How to skip all kinds of thoose creation dialogs?
Link to proper documentation page will be sufficient.
Thanks a lot.
(There was once similar question but using IValidate<T> is no generic solution.)
