Episerver 11 - DisplayTemplates for LinkItemCollection
Alloy, Episerver 11.10.1.
On StartPage, I've created a new property:
[UIHint("MyUiHint")]
[Display(
    GroupName = SystemTabNames.Settings,
    Order = 100)]
public virtual LinkItemCollection MyProperty{ get; set; }
Under Views/Shared/DisplayTemplates, I've created a new view - MyUiHint.cshtml
If I use @Html.PropertyFor(x => x.CurrentPage.MyProperty) inside Views/StartPage/Index.cshtml, everything works as expected. Episerver will use MyUiHint.cshtml to render the property.
However, if I want to make MyProperty available inside LayoutModel and use @Html.PropertyFor(x => x.Layout.MyProperty), Episerver will use the default template instead of MyUiHint.cshtml. If I then click on the property in On-Page editing mode and close the popup, Episerver will switch to MyUiHint.cshtml. However, as soon as I switch the view (for example, go to All Properties view and then back to On-Page editing view), Episerver will again use the default template instead of MyUiHint.cshtml.
Is this a known issue?
#199610
Dec 03, 2018 19:58
CMS-12607
#199728
Dec 07, 2018 13:31
