Hi Roman,
It's not something I've worked with before but you'll want to make use of the PersonalizedViewSettingsManager and/or the IPersonalizedViewSettingsRepository Interface.
I just put together this sample which shows creating a tab, naming it 'Test' and adding a Notes gadget to it:
var viewManager = ServiceLocator.Current.GetInstance<IViewManager>();
var personalizedViewSettingsManager = ServiceLocator.Current.GetInstance<PersonalizedViewSettingsManager>();
var componentManager = ServiceLocator.Current.GetInstance<IComponentManager>();
var user = HttpContext.User;
const string dashboardViewName = "/episerver/dashboard";
ICompositeView compositeView = viewManager.CreateView(dashboardViewName, user);
// Get the tab container, this should always be below our root container
var tabContainer = (TabContainer)compositeView.RootContainer.Components.First(x => x.DefinitionName.Equals(typeof(TabContainer)
.FullName));
PersonalizedViewSettings personalizedViewSettings;
IContainer container;
tabContainer = (TabContainer)personalizedViewSettingsManager.GetOrCreatePersonalizedComponent(user,
dashboardViewName, tabContainer.Id, out personalizedViewSettings, out container);
// Create a ComponentContainer for our new tab
var singleTabContainer = (ComponentContainer)componentManager.CreateComponent(typeof(ComponentContainer).FullName, user);
tabContainer.Add(singleTabContainer);
var notesComponent = componentManager.CreateComponent("EPiServer.Cms.Shell.UI.Controllers.NotesController", user);
// Set the heading & add the notes gadget
singleTabContainer.Settings["personalizableHeading"] = "Test";
singleTabContainer.Add(notesComponent);
personalizedViewSettingsManager.Repository.Save(personalizedViewSettings);
There are very likely some improvements that can be made to this - but it should give you a starting point.
/Jake
Hello,
Is it possible to work with dashboard via code.
For example: Create Tab and gadget inside it? Or delete it?
