UrlResolver instance is null
I am trying to get a friendly-url for a page of type ContentReference (property in site settings) in another page's controller.
In site settings:
public virtual ContentReference NewsletterSuccessPageRef { get; set; }
In the base controller I am populating the "Model" in override method OnActionExecuting():
protected override void OnActionExecuting(ActionExecutingContext filterContext)
			base.OnActionExecuting(filterContext);
			var currentPage = filterContext.ActionParameters.First(ap => ap.Value is TPage).Value as TPage;
			var currentContent = filterContext.ActionParameters.First(ap => ap.Value is TContent).Value as TContent;
			Model = filterContext.ActionParameters.FirstOrDefault(ap => ap.Value is TViewModel).Value as TViewModel;
			InitializeModel(currentPage, currentContent);
Other page's controller:
var urlResolver = ServiceLocator.Current.GetInstance<UrlResolver>();
var url = urlResolver.GetUrl(Model.SiteSettings.NewsletterSuccessPageRef);
But I get a NullReference exception on line 21:
Object reference not set to an instance of an object.
Exception Details: System.NullReferenceException: Object reference not set to an instance of an object.
Source Error:
Line 19:
Line 20: 			var urlResolver = ServiceLocator.Current.GetInstance<IUrlResolver>();
Line 21: 			var url = urlResolver.GetUrl(Model.SiteSettings.NewsletterSuccessPageRef);
Line 22:
Debugging shows that neither the "urlResolver" nor the "SiteSettings.NewsletterSuccessPageRef" are null.
Any ideas why?
Regards,
Micha
#199514
Edited, Nov 29, 2018 10:28
Which version are you running? There is a bug reported for that issue, see https://world.episerver.com/support/Bug-list/bug/CMS-9578 that is fixed in CMS.Core 11.3.3
#199516
Nov 29, 2018 11:37
are yopu getting the Contentlink on your Model.Settings.NewletterSuccess?
#199525
Edited, Nov 29, 2018 15:07
Running a version below 11.3.3 and currently there is no option to upgrade. I have tried the workaround suggested in the bug you linked with no success (getting the same results). Is there another way to get the friendly url of a page?
@Radek Yes, contentLink is available as usual
Thanks a lot!
#199527
Nov 29, 2018 15:22
in one fragment you are asking for `UrlResolver` in another code snippet - `IUrlResolver`. are both of them `null`? If you try to get instance of resolver "somewhere" else - does it work there?
#199577
Dec 01, 2018 5:21
