I'm experiencing something very strange.
I've tried to implement custom TinyMCE settings so I've created the following class :
[ServiceConfiguration(ServiceType = typeof(PropertySettings))]
public class MyTinyMCESettings : PropertySettings
public MyTinyMCESettings ()
DisplayName = "Americares Simple Editor";
public override TinyMCESettings GetPropertySettings()
var settings = new TinyMCESettings();
settings.ToolbarRows.Add(new ToolbarRow(new string[]
TinyMCEButtons.Anchor,
TinyMCEButtons.EPiServerLink, TinyMCEButtons.Unlink, TinyMCEButtons.Image,
TinyMCEButtons.EPiServerImageEditor, TinyMCEButtons.Media, TinyMCEButtons.EPiServerPersonalizedContent,
TinyMCEButtons.Cut, TinyMCEButtons.Copy, TinyMCEButtons.Paste, TinyMCEButtons.PasteText,
TinyMCEButtons.PasteWord, TinyMCEButtons.Fullscreen, TinyMCEButtons.SuperScript,
TinyMCEButtons.SubScript,
TinyMCEButtons.Underline, TinyMCEButtons.JustifyCenter,
TinyMCEButtons.JustifyLeft, TinyMCEButtons.JustifyRight, TinyMCEButtons.JustifyFull,
TinyMCEButtons.HorizontalRow, TinyMCEButtons.FormatSelect, "twitterquotebutton", "customimageeditorbutton"
TinyMCEButtons.Bold, TinyMCEButtons.Italic, TinyMCEButtons.Separator, TinyMCEButtons.BulletedList,
TinyMCEButtons.NumericList, TinyMCEButtons.StyleSelect, TinyMCEButtons.Undo, TinyMCEButtons.Redo,
TinyMCEButtons.Search, TinyMCEButtons.FontSelect, TinyMCEButtons.FontSizeSelect,
TinyMCEButtons.ForeColor, TinyMCEButtons.ForeColorPicker
// Add the default non-visual plugins that replaces built in functionality with EPiServer specifics.
settings.NonVisualPlugins.Add("advimage");
settings.NonVisualPlugins.Add("epifilebrowser");
settings.ToolbarRows[1].Buttons.Add(TinyMCEButtons.Code);
settings.Height = 300;
settings.Width = 580;
return settings;
public override System.Guid ID
get { return new System.Guid("37ABF48F-8DFC-4C28-BD23-1E14655F6526"); }
On the desired properties I've put the MyTinyMCESettings tag.
But sometimes when I try to create a block which has a property annotated with the custom settings class I experience something strange.
That property is being displayed in the cms as a text area and i cannot even write text on it . I also get a script error as you can see in the following images :
I get this only if i try to create a new block from clicking " create a new block" within a CONTENT AREA. If however I try to create the same block from the Assets Pane the behaviour is normal and i dont get the errors..
