i would also like that, it would make blokcs in tinyMCE a lot more usefull
We are currently upgrading to EPiServer and of course timymce 2.6.1.
We have a lot of dynamic content i our Xhtml text, they appear as span in edit mode of tinymce and only a string of two or three caracters in view mode.
After migrating to blocks, there is a major problem, in edit mode of tinyMCE all the block shows within div tags.
TinyMCe creates then
tags around this div which is right since you can't have div in p tags to be compliant.
But the problem is obviously that the xhtml is now wrong with all those p tags around.
This was solved with the property "RenderAsBlockElement" set to false in dynamic content.
How can I make a block in edit mode in tinyMCE displays with span tags instead of div.
Before :
text tex text texte tgeasa
After migrating :
text tex text
texte tgeasa
