Custom Property not rendering as expected
I'm trying to implement a custom property, much like this one: https://gregwiechec.com/2016/05/textarea-with-statistics/
Template file DojoProperty2.html:
I'm alive!!
Characters: 0
Words: 0
Lines: 1
Looks like this if I open the file in the browser:
But in the CMS I only get this:
DojoProperty.js:
define([
    "dojo/_base/declare",
    "dijit/_Widget",
    "dijit/_TemplatedMixin",
    'dojo/text!./DojoProperty2.html',
    function (
        declare,
        _Widget,
        _TemplatedMixin,
        template
        return declare("jondjones.CustomProperty.DojoProperty", [
            _Widget,
            _TemplatedMixin], {
                templateString: template
DojoPropertyEditorDescriptor.cs:
using EPiServer.Shell.ObjectEditing.EditorDescriptors;
using System;
using System.Linq;
using System.Web;
namespace TemplateTest.Business.EditorDescriptors
    [EditorDescriptorRegistration(
            TargetType = typeof(String),
            UIHint = "CustomProperty")]
    public class DojoPropertyDescriptor : EditorDescriptor
        public DojoPropertyDescriptor()
            ClientEditingClass = "alloy/editors/DojoProperty";
TeaserBlock.cs: (where the property is being used)
using System.ComponentModel.DataAnnotations;
using EPiServer.Core;
using EPiServer.DataAbstraction;
using EPiServer.DataAnnotations;
using EPiServer.Web;
namespace TemplateTest.Models.Blocks
    /// Used to provide a stylized entry point to a page on the site
    [SiteContentType(GUID = "EB67A99A-E239-41B8-9C59-20EAA5936047")] // BEST PRACTICE TIP: Always assign a GUID explicitly when creating a new block type
    [SiteImageUrl] // Use site's default thumbnail
    public class TeaserBlock : SiteBlockData
        [Display(
            Name = "Custom Property3",
            Description = "Custom Property Desc3",
            Order = 1)]
        [UIHint("CustomProperty3")]
        public virtual string CustomProperty3 { get; set; }
        [CultureSpecific]
        [Required(AllowEmptyStrings = false)]
        [Display(
            Order = 1)]
        public virtual string Heading { get; set; }
        [CultureSpecific]
        [Display(
            Order = 2)]
        [UIHint(UIHint.Textarea)]
        public virtual string Text { get; set; }
        [CultureSpecific]
        [UIHint(UIHint.Image)]
        [Display(
            Order = 3)]
        public virtual ContentReference Image { get; set; }
        [Display(
            Order = 4)]
        public virtual PageReference Link { get; set; }
TeaserBlock.cshtml:
@using EPiServer.Core
@using TemplateTest.Controllers
@model TeaserBlock
@Html.PropertyFor(m => m.CustomProperty3)
@*Link the teaser block only if a link has been set and not displayed in preview*@ @using (Html.BeginConditionalLink( !ContentReference.IsNullOrEmpty(Model.Link) && !(ViewContext.Controller is PreviewController), Url.PageLinkUrl(Model.Link), Model.Heading)) {
x.Heading)>@Model.Heading
x.Text)>@Model.Text
x.Image)>
What am I doing wrong?
Version: 11.10.1.0
#198912
Nov 08, 2018 13:43
Hi Beatrice,
How does your module.config look?
/Jake
#198917
Nov 08, 2018 18:03
In your model, you have:
Should this be "CustomProperty3" as UIHint instead of "CutomProperty" from EditorDescriptor?
#198918
Nov 08, 2018 21:20
This is what it looks like:
<module>
    <assemblies>
	    <!-- This adds the Alloy template assembly to the "default module" -->
        <add assembly="TemplateTest" />
    </assemblies>
    <clientResources>
        <add name="epi-cms.widgets.base" path="Styles/Styles.css" resourceType="Style"/>
    </clientResources>
    <dojo>
        <!-- Add a mapping from alloy to ~/ClientResources/Scripts to the dojo loader configuration -->
        <paths>
            <add name="alloy" path="Scripts" />
        </paths>
    </dojo>
</module>
#198942
Nov 09, 2018 10:37
#198943
Nov 09, 2018 10:37
