How to get IContentLoader using constructor injection
I have this code
var loader = EPiServer.ServiceLocation.ServiceLocator.Current.GetInstance();
I want to get the instance of IContentLoader using constructor injection.
How i can do that.
#198425
Edited, Oct 29, 2018 5:36
You should be using something like this
public class MyClass
privat IContentLoader _contentLoader;
public MyClass(IContentLoader contentLoader)
_contentLoader = contentLoader;
#198430
Oct 29, 2018 7:48
Hi Janmejay,
You have to set Dependency Resolver in ASP.NET.
This is a code sample from Alloy:
[InitializableModule]
    public class DependencyResolverInitialization : IConfigurableModule
            DependencyResolver.SetResolver(new ServiceLocatorDependencyResolver(context.Locate.Advanced));
    public class ServiceLocatorDependencyResolver : IDependencyResolver
        readonly IServiceLocator _serviceLocator;
        public ServiceLocatorDependencyResolver(IServiceLocator serviceLocator)
            _serviceLocator = serviceLocator;
        public object GetService(Type serviceType)
            if (serviceType.IsInterface || serviceType.IsAbstract)
                return GetInterfaceService(serviceType);
            return GetConcreteService(serviceType);
        private object GetConcreteService(Type serviceType)
            try
                // Can't use TryGetInstance here because it won’t create concrete types
                return _serviceLocator.GetInstance(serviceType);
            catch (ActivationException)
                return null;
        private object GetInterfaceService(Type serviceType)
            object instance;
            return _serviceLocator.TryGetExistingInstance(serviceType, out instance) ? instance : null;
        public IEnumerable<object> GetServices(Type serviceType)
            return _serviceLocator.GetAllInstances(serviceType).Cast<object>();
You can find documentation on this link: https://world.episerver.com/documentation/developer-guides/CMS/initialization/dependency-injection/
#198436
Edited, Oct 29, 2018 9:26
