Detect CMS login
Hello,
Forgive me if this is a simple query or something I've missed.
I'm trying to record login activity for all CMS users. But I couldn't see any way to retrieve user login history, as there doesn't appear to be a global "OnUserLogin" event that I can hook into. And unless I'm mistaking, I don't think there is in the SqlMembershipProvider libary either.
Has anyone tackled this previously? I'd imagine it's a fairly regular use case to maintain a record of login history for auditing.
Thanks.
#197950
Edited, Oct 17, 2018 19:02
Login is not really part of the product so I think there is nothing built-in.
You could replace and disable the default login page and make your own where you log login history.
Another option is to add an INSERT statment to the appropriate aspnet_Membership_* stored procedure. I don't think they have ever been changed.
#197951
Oct 17, 2018 19:53
Scott Reed
If you're using asp.net identity which is the OOTB providoer or even the owin provider with the standard CookingAuthenticationOptions there's an event you can hook in to for when a user logs int hat allows you to get the login of the user and the associated claims.
Check out the example below where the OnResponseSignIn = METHOD
 // Use cookie authentication
            app.UseCookieAuthentication(new CookieAuthenticationOptions
                AuthenticationType = DefaultAuthenticationTypes.ApplicationCookie,
                LoginPath = new PathString(LoginPath),
                Provider = new CookieAuthenticationProvider
                    // If the "/util/login.aspx" has been used for login otherwise you don't need it you can remove OnApplyRedirect.
                    OnApplyRedirect = cookieApplyRedirectContext =>
                        app.CmsOnCookieApplyRedirect(cookieApplyRedirectContext, cookieApplyRedirectContext.OwinContext.Get<ApplicationSignInManager<ApplicationUser>>());
                    // Enables the application to validate the security stamp when the user logs in.
                    // This is a security feature which is used when you change a password or add an external login to your account.
                    OnValidateIdentity = SecurityStampValidator.OnValidateIdentity<ApplicationUserManager<ApplicationUser>, ApplicationUser>(
                        validateInterval: TimeSpan.FromMinutes(30),
                        regenerateIdentity: (manager, user) => manager.GenerateUserIdentityAsync(user)),
                    OnResponseSignedIn = OnResponseSignedIn
Just create a method to handle this such as
        /// <summary>
        /// Called when the user has signed in.
        /// </summary>
        /// <param name="cookieResponseSignedInContext">The cookie response signed in context.</param>
        private void OnResponseSignedIn(CookieResponseSignedInContext cookieResponseSignedInContext)
#198004
Edited, Oct 18, 2018 16:39
