Kartheek,
Can you tell us which Epi version you are using? Also, are you using the new Forms add-on (the one documented on this page:https://world.episerver.com/documentation/developer-guides/forms/)?
Hi Kartheek
I wrote about creating a custom form field for Episerver Forms here:
https://www.david-tec.com/2016/01/building-out-a-custom-form-element-with-the-new-episerver-forms/
Let me know if it helps.
David
Hi David,
i have already gone through the link,but the example is not working as expected.can you suggest any other referance.
Kartheek
Hey, Kartheek,
I have an email element block. It is built as an Add-On, but you could take it for inspiration.
Btw, where did you place your cshtml?
BR,
Marija
Hi Marija Jemuovic,
Thanks for your time consideration of this matter,i placed my .cshtml in Shared-->blocks-->Myview.cshtml.
Kartheek.
Hey,
Does it work if you move it to Views / Shared / ElementBlocks?
BR,
Marija
Thanks Marija Jemuovic,
Your reference email block element is helpfull for creating textbox.
Kartheek.
Hi Guys,
As per requirement i want to create my own form field,but when i drag and drop field its not displayed here is my code
namespace EpiserverSite5.Models.Blocks
[ContentType(DisplayName = "CustomTextBoxElementBlock", GUID = "c5230b6e-7da0-4400-942c-0f33b6f801b6", Description = "")]
public class CustomTextBoxElementBlock : TextboxElementBlock
[Display(
Name = "Max length",
Description = "The maximum number of characters.",
Order = 2999)]
public virtual int? MaxLength { get; set; }
CustomTextBoxElementBlock.cshtml
@model EpiserverSite5.Models.Blocks.CustomTextBoxElementBlock
@using System.Web.Mvc
@using EPiServer.Forms.Helpers.Internal
@using EPiServer.Forms.Implementation.Elements
@using EPiServer.Forms.EditView.Internal
@using EPiServer.ServiceLocation
var errorMessage = Model.GetErrorMessage();
var errorStyle = string.IsNullOrEmpty(errorMessage) ? " display:none" : string.Empty;
var validationService = ServiceLocator.Current.GetInstance
data-f-element-name="@Model.FormElement.ElementName" data_f_type="textbox">
id="@Model.FormElement.Guid"
type="text"
class="FormTextbox FormTextbox__Input @Model.FormElement"
placeholder="@Model.PlaceHolder"
value="@Model.GetDefaultValue()"
@Html.Raw(Model.AttributesString) />
class="Form__Element__ValidationError"
style="@errorStyle">@errorMessage
@Model.RenderDataList()
When i drag form fied into form container,i get this error
Error:
The 'CustomTextBoxElementBlock' can not be displayed
Can any one help me out of this.
Kartheek
