TinyMCE XHtml-editor icons missing
I have stumbled on a problem with icons in the TinyMCE editor. Some of them are missing.
I'm using a manualy edited TinyMCE editor.
When I check to edit which icons to be shown, the icons for ImageVault plugin and editor are there.
But when I'm editing the main body of a page (which uses the specific TinyMCE editor) the icons aren't there.
Is there a easy solution for this?
Best Regards
Niklas
#187320
Jan 19, 2018 9:03
Are the plugins (ImageVault etc) enabled on the default configuration? Does the page and property you're looking at have any custom settings that might be overriding it?
#187346
Jan 19, 2018 15:50
ImageVault are enabled and the page and property uses custom TinyMCE editor settings set up directly in admin mode. In the TinyMCE settings I can see the icons for edit and add imagevault media, and they are added to the toolbar.
But in edit mode they are missing.
The current version of episerver i cms 9.9 and imagevault is ImageVault.Client and ImageVault.Common is 4.8.251 and ImageVault.EPiServer and ImageVault.EPiServer.UI is 4.8.240.
#187446
Jan 23, 2018 11:00
I got it to work. I had to upgrade ImageVault to a later version (that was still compatible with Episerver 9). Still weird that the buttons/icons just went missing.
#187455
Jan 23, 2018 13:36
