Episerver 10 - Disable Dyanamic Datastore caching
Would like to disable DDS caching.  Is this possible? if so how do I go about doing this?
edit:  I see this line  [EPiServerDataStore(AutomaticallyCreateStore = true, AutomaticallyRemapStore = true )]
I'm guessing somehow I disable in the line above but I'm not sure how and the documentation points to older versions where this is in the web/app config.
thank you
#187422
Edited, Jan 22, 2018 21:01
You can configure DDS to use NullCacheProvider that doesn't use caching, see https://world.episerver.com/documentation/developer-guides/CMS/configuration/Configuring-episerverdataStore/
#187536
Jan 25, 2018 12:50
