Edit mode blank
Hello, since a couple of days the out edit mode is blank. Admin works fine and the site istelf works fine. We have not deployed a new version in the last month. Everything works fine in our test and development enviorment.
The client complains about a dojo.js error.
Uncaught SyntaxError: Unexpected token <>
widgets.js:2 Uncaught TypeError: Cannot read property 'ok' of undefined
at widgets.js:2
at _c8 (dojo.js:15)
at _36 (dojo.js:15)
at _36 (dojo.js:15)
at _36 (dojo.js:15)
at _36 (dojo.js:15)
at _36 (dojo.js:15)
at _36 (dojo.js:15)
at dojo.js:15
at _37 (dojo.js:15)
(anonymous) @ widgets.js:2
_c8 @ dojo.js:15
_36 @ dojo.js:15
_36 @ dojo.js:15
_36 @ dojo.js:15
_36 @ dojo.js:15
_36 @ dojo.js:15
_36 @ dojo.js:15
(anonymous) @ dojo.js:15
_37 @ dojo.js:15
_7c @ dojo.js:15
_f0 @ dojo.js:15
_10a @ dojo.js:15
9VM843 global:1 Uncaught SyntaxError: Unexpected token <>
#187173
Jan 15, 2018 13:13
Anything that could possible inject into all javascript requests? Like license error or monitoring module?
#187175
Jan 15, 2018 13:28
The license is ok and we don't have any modules/plugins installed except the standard episerver ones.
#187179
Jan 15, 2018 14:50
#187180
Jan 15, 2018 14:56
Do you have Web Accessibility Checker VS extension installed? Try disabling it.
#187188
Jan 15, 2018 19:38
The problem is in production. No VS installed there and I don't have any problems in development.
#187193
Jan 15, 2018 20:28
Sometimes restarting IIS helps.
#187195
Jan 15, 2018 21:37
Restared the site and app pool. That did not help. Can try with a complete IIS restart.
#187196
Jan 15, 2018 21:44
I would suggest installing EPiServer.CMS.UI.Sources from nuget and add
<clientResources debug="true" />
inside the <episerver.framework> node in web.config
That way you will get uncompressed files and hopefully you will see something with a little more meaning after a deploy to production
Bloggpost: https://world.episerver.com/blogs/Ben-McKernan/Dates/2014/8/Uncompressed-JavaScript-for-EPiServer-76/
#187197
Edited, Jan 15, 2018 22:14
Found it.
We have multiple languages installed on the site and some scripts was calling the shell with the language in the url ie ".../Shell/10.8.0.0/ClientResources/EPi/cms/nls/en-xy/episerver.cms.js".
Since this language was not in use anymore we made a rewrite rule on it to go to another language. This works fine on the site itself since yhe js files there does not have any culture in the source url. But this messed up the edit mode.
Thanks for your help.
#187198
Jan 15, 2018 22:18
