XhtmlString is not rendering as HTML
I have a problem in Alloy project .
I have created a HTML block which  will render  html ,but the problem is when we are going to add HTMl text .In back end the html button is not showing and If i add some custom html tag it is not rendering as html.can you please help .
#182281
Sep 14, 2017 12:46
(Being annoying and not helping for now but..) you should probably ask in the CMS forum :) This is not a Commerce related question, but rather CMS. And the CMS forum has much more activity, so better chance of getting help!
Edit: Admins moved it. My comment looks weird embarassed
#182285
Edited, Sep 14, 2017 13:22
You are missing the HTML button in the rich text editor in EPiServer? Try adding this attribute to your property on your page type:
[PropertySettings(typeof(AdvancedIncludingHtmlTinyMceSettings))]
If your text string doesn't render as HTML (a XhtmlString should indeed), you can perhaps achieve this with @Html.Raw(Model.MyProperty)
I hope this was helpful.
#182287
Sep 14, 2017 14:28
If you are trying to render HTML from a XhtmlString without @Html.PropertyFor() I would recommend you to use @Html.XhtmlString(xhtmlString). Otherwise links will not be converted and blocks will not be displayed.
#191119
Apr 20, 2018 11:28
#191197
Apr 23, 2018 19:26
