Retrieve changed pages from EpiServer database with sql script
I'm wondering how I can get hold of the changed date for a published page with sql.
We are using EPiServer.CMS.Core.10.4.3, EPiServer.Find.Framework.12.4.3
In code we do the following:
var query = searchInstance.Search();
query = query.Filter(x => x.Changed.InRange(DateTime.MinValue, todaysDate.AddMonths(-10))).FilterForVisitor();
query = query.Filter(x => !x.Ancestors().Match(startPage.ArchivePage.ID.ToString()));
(IRemindable inherits IContent and has a property DateTime Changed)
#182897
Sep 29, 2017 13:32
Why do you need to do it in SQL?
#182976
Oct 02, 2017 22:14
The customer wants to receive a list of pages that hasn't been modified since a given date from production as a one time thing.
#182995
Oct 03, 2017 9:34
You could work something out starting with [tblContentLanguage]. It has the datetime columns you need.
#183025
Oct 03, 2017 13:48
Hi Angelica
I wrote this quick SQL query that returns the Content ID of pages matching your criteria.
It looks after a property called Changed, like you mentioned. If it is less than or equal to 10 months ago, it is returned.
I did not test it with language branches.
DECLARE @MinDate datetime
SET @MinDate = DATEADD(m, -10, GETDATE())
PRINT @MinDate
SELECT c.pkID
	FROM tblContent c
	WHERE
		c.ArchiveContentGUID IS NULL AND
		c.pkID IN
			(SELECT cp.fkContentID
			FROM tblContentProperty cp
			INNER JOIN tblPropertyDefinition pd ON pd.pkID = cp.fkPropertyDefinitionID
			WHERE pd.Name = 'Changed' AND cp.Date IS NOT NULL AND cp.Date <= @MinDate)
#183026
Oct 03, 2017 13:54
Thanks!
I will try to do that! :)
#183027
Oct 03, 2017 13:56
