Overwrite PageData.Changed on save/publish
Is it possible to change Changed property of PageData object? I'm trying to set a date in the past but it always saves the current date. I tried to set it both on save new object and on publish modifier object and nothing works. Setting SetChangedOnPublish does not affect the result.
TOutput output = _contentRepository.GetDefault(parentReference);
(set other properties)
output.Changed = someDateInput;
_contentRepository.Save(output, SaveAction.Save, AccessLevel.NoAccess);
var output = (TOutput)readOnlyOutput.CreateWritableClone();
_contentRepository.Save(output, SaveAction.Publish | SaveAction.ForceCurrentVersion, AccessLevel.NoAccess);
output object has expected Changed date while I pass it to Save() method.
I use EPiServer CMS 9.
#182550
Edited, Sep 22, 2017 13:15
