we had these cases when more than single developer sharing the same db and somebody on the team just fool around content types (like creating new ones or deleting old ones)
I think you are right. It all magically resolved itself when trying in the evening when no one else was using the db. Thanks!
I have just installed the Episerver.Forms nuget package to my solution. When I'm creating a form, I can use some of the simple form elements like text and text area, but when I try to use i.e numbers, fileupload, image etc, I get the following error. Any tips?
The INSERT statement conflicted with the FOREIGN KEY constraint "FK_tblContent_tblContentType". The conflict occurred in database " XXXXXXXX", table "dbo.tblContentType", column 'pkID'.
Exception Details: System.Data.SqlClient.SqlException: The INSERT statement conflicted with the FOREIGN KEY constraint "FK_tblContent_tblContentType". The conflict occurred in database " XXXXXXXX", table "dbo.tblContentType", column 'pkID'.
Source Error:
Stack Trace:
[SqlException (0x80131904): The INSERT statement conflicted with the FOREIGN KEY constraint "FK_tblContent_tblContentType". The conflict occurred in database " XXXXXXXX", table "dbo.tblContentType", column 'pkID'.]
System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction) +3277272
System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose) +345
System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady) +5002
System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString, Boolean isInternal, Boolean forDescribeParameterEncryption) +492
System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async, Int32 timeout, Task& task, Boolean asyncWrite, Boolean inRetry, SqlDataReader ds, Boolean describeParameterEncryptionRequest) +3152
System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, TaskCompletionSource`1 completion, Int32 timeout, Task& task, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry) +704
System.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(TaskCompletionSource`1 completion, String methodName, Boolean sendToPipe, Int32 timeout, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry) +512
System.Data.SqlClient.SqlCommand.ExecuteNonQuery() +406
EPiServer.DataAccess.Internal.ContentSaveDB.CreateNewContent(IContent content, String currentUser) +1396
EPiServer.DataAccess.Internal.<>c__DisplayClass23_0.<SaveInternal>b__0() +46
EPiServer.Data.Providers.Internal.<>c__DisplayClass32_0.<ExecuteTransaction>b__0() +15
EPiServer.Data.Providers.Internal.<>c__DisplayClass33_0`1.<ExecuteTransaction>b__0() +58
EPiServer.Data.Providers.SqlTransientErrorsRetryPolicy.Execute(Func`1 method) +816
EPiServer.DataAccess.Internal.ContentSaveDB.SaveInternal(IContent content, SaveOptions options) +243
EPiServer.DataAccess.Internal.ContentSaveDB.Save(IContent content, SaveAction action, String currentUser) +297
EPiServer.Core.Internal.DefaultContentProviderDatabase.Save(IContent content, SaveAction action, String currentUser) +50
EPiServer.Core.Internal.DefaultContentProvider.Save(IContent content, SaveAction action) +79
EPiServer.Core.Internal.DefaultContentRepository.Save(IContent content, SaveAction action, AccessLevel access) +757
EPiServer.Forms.EditView.Controllers.FormsElementStore.GetElementByType(Int32 typeId, String parentLink) +533
lambda_method(Closure , ControllerBase , Object[] ) +195
System.Web.Mvc.ReflectedActionDescriptor.Execute(ControllerContext controllerContext, IDictionary`2 parameters) +229
System.Web.Mvc.ControllerActionInvoker.InvokeActionMethod(ControllerContext controllerContext, ActionDescriptor actionDescriptor, IDictionary`2 parameters) +35
System.Web.Mvc.Async.AsyncControllerActionInvoker.<BeginInvokeSynchronousActionMethod>b__39(IAsyncResult asyncResult, ActionInvocation innerInvokeState) +39
System.Web.Mvc.Async.WrappedAsyncResult`2.CallEndDelegate(IAsyncResult asyncResult) +71
System.Web.Mvc.Async.AsyncControllerActionInvoker.EndInvokeActionMethod(IAsyncResult asyncResult) +42
System.Web.Mvc.Async.AsyncInvocationWithFilters.<InvokeActionMethodFilterAsynchronouslyRecursive>b__3d() +72
System.Web.Mvc.Async.<>c__DisplayClass46.<InvokeActionMethodFilterAsynchronouslyRecursive>b__3f() +386
System.Web.Mvc.Async.AsyncControllerActionInvoker.EndInvokeActionMethodWithFilters(IAsyncResult asyncResult) +42
System.Web.Mvc.Async.<>c__DisplayClass2b.<BeginInvokeAction>b__1c() +38
System.Web.Mvc.Async.<>c__DisplayClass21.<BeginInvokeAction>b__1e(IAsyncResult asyncResult) +186
System.Web.Mvc.Async.AsyncControllerActionInvoker.EndInvokeAction(IAsyncResult asyncResult) +38
EPiServer.Shell.Services.Rest.RestControllerBase.EndExecute(IAsyncResult asyncResult) +60
System.Web.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +399
System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +157
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.6.1590.0
