Aman, Does this help? https://world.episerver.com/documentation/Class-library/?documentId=cms/9/389DE73D
Hello,
I contact episerver support and they have given me this link
https://developers.google.com/maps/documentation/javascript/get-api-key
to get a key and in applicationSettings in web.config add
<applicationSettings googleMapsApiV3Url="https://maps.google.com/maps/api/js?key=your_generated_key" ... />
Do we just have to add <applicationSettings googleMapsApiV3Url="https://maps.google.com/maps/api/js?key=your_generated_key" ... /> in web.config to see this working or any other configuration is needed? becasuee its not working for me
Hello,
Yes, This is the Response that I got from episerver support.
I go to this url (https://developers.google.com/maps/documentation/javascript/get-api-key)to get a key and in applicationSettings in I got it working by this
<applicationSettings googleMapsApiV3Url="https://maps.google.com/maps/api/js?key=AIzaSyA9C6Z0iKdwRBJ9Hi5Qx7JOw0U0AC7RrLc" ... />
I hope this makes sense.
I login with gmail account to get the api key.
I think something is there which i am missing.
In my local Alloy Project, I have added <add key="googleMapsApiV3Url" value="https://maps.google.com/maps/api/js?key=AIzaSyBv_AtEaksqFXM7yLv2UptqKEcGa8MZ6Ko" /> in web.config -> <appSettings>
and it doesnt work.
When i add a criteria, geographic coordinate to a group, and try to Select Location , it doesnt open a map instead a dialog box with instructions and a link on how to configure google maps . any clue?
I notice that my visitor group where i use Geographic Location criteria, doesnt work too. I guess this criteria doesnt need any congifuration other than geolocation maxmind which is inbuilt in alloy project. Any clue on this?
As Aman is mentioning above, you have to add the "googleMapsApiV3Url" key in Web.config, inside <episerver> tag:
<episerver> <applicationSettings googleMapsApiV3Url="https://maps.google.com/maps/api/js?key=your_generated_key" /> </episerver>
Hello,
I am creating a visitor group criteria Geographic Coordinate [Time and Place Criteria]. When I clicked on select location tab. I am getting an error in pop up window.
"Oops! Something went wrong.
This page didn't load Google Maps correctly. See the JavaScript console for technical details."
When I check console I am getting Google Maps API error: MissingKeyMapError https://developers.google.com/maps/documentation/javascript/error-messages#missing-key-map-error on console.
I know I have to generate an API key. But where I have to use that API key in episerver to solve the Missing Key Map Error.
Aman Mehta
