Switch to [CultureSpecific(false)] for existing property
I was trying to switch a [CultureSpecific(true)] [Required] propert to [CultureSpecific(false)]. And locally everything goes ok. But on the test server the change has not picked up. Maybe because there is some multicultural data already. I am not sure.
Local: http://prntscr.com/gce704
Tst: http://prntscr.com/gce76j
EPiServer verision is 10.3
The possible workaround I see here - simply to change this property via Admin->Content Types
#181551
Edited, Aug 24, 2017 10:39
Most probably data exist for those types in test environment, I doubt that via Admin also this will be possible without losing data.
#181582
Aug 24, 2017 15:58
So seems to be the only option is to Reset to default for the property...
In this case the master langage data will be still availible and all other languages data will be lost
#181641
Edited, Aug 25, 2017 13:57
