Custom dojo property editor, get saved value from the server
Hello,
I am having problems getting the property value from the server after it has been changed in the "OnSaving" event on the server.
Is there a way to get the updated value when a custom property with a dojo editor is saved("onChange(newValue)" is called) and the value is changed in the "OnSaving" event on the server?
/Peter
#181825
Aug 31, 2017 10:32
Hi Peter,
Just so I understand the problem:
  1. user enters the property value
  2. onSaving is triggered on the server
  3. the entered value is changed in the c# event handler
expected: ?
actual: ?
thanks,
Bart
#181942
Sep 06, 2017 8:54
Hello,
Expected: The value changed on the server is returned to the client and the value on the client is changed or atleast returned so that the js can manage it.
Actual: The value is not updated on the client or the JS notified that it has changed.
In this use case its a third party custom property that contains a few hidden values that the client never see but is used in the JS. One of those is changed in the OnSaving event on the server.
I managed to get it to work without the updated value so this is no longer a problem in this case.
What is the expected behavior when a value is changed on the server? Maybe the error is in how the custom property handles changes.
Peter
#181955
Sep 06, 2017 10:02
