There's nothing really built in.
I would suggest that you either have an IList Property and use my SelectionFactory for content with a SelectOneAttribute.
[SelectOne(SelectionFactoryType = typeof(ContentSelectionFactory<MyBlock>))]
public virtual ContentReference MyContentReference { get; set }
Otherwise a simple way to do it (but not so elegant) is to have a string property, use the SelectMany attributes with my SelectionFactory for content.
[SelectMany(SelectionFactoryType = typeof(ContentSelectionFactory))]
public virtual string MyTeasers { get; set; }
However you want to remove the default value on row 22.
allContent.Add(new SelectItem());
The value of the property will be a comma separated string with ContentReference IDs "123,456".
You will yourself split that string by comma, parse the PageReference for each string and load each Block.
var myTeasers = CurrentPage.MyTeasers;
var teaserArray = myTeasers.Split(new [] { ',' }, StringSplitOptions.None);
var contentLinks = teaserArray.Select(x => new PageReference(x));
var blocks = contentLoader.GetItems(contentLinks, LanguageSelector.AutoDetect());
The code is just quickly thrown together so some adjustments might be needed to suit exactly what you want.
I've been searching everywhere for this example, so far haven't found anything. Hence the post here. Is there a way to have a list of checkboxes to select a particular block type from that list, from the editor?
Thanks in advance.
