That type has been moved to an internal namespace, so now the type is (including namespace) EPiServer.Web.Routing.Segments.Internal.RequestSegmentContext. The move was part of a larger code refactoring that was done in the major release 9->10.
In your case it seems that something (from stacktrace it seems to be ImageResizer) has serialized that type to some storage and then tries to deserialize it, which will fail as above since the type has been moved.
I upgraded the ImageResizer nuget package and this resolved my issue.
Thanks!
-Paul
I'm in the process of upgrading Episerver from 9.8, to 10.10.1. During this process, I've hit a ton of issues but I'm making my way through them. The latest issues however I'm not sure where to start. I'm getting an error while trying to load up EPiServer.Web.Routing.Segments.RequestSegmentContext, however, I see no reference to this in my solution/codebase.
Where would be a good place to start debugging this issue?
My specific error is...
Could not load type 'EPiServer.Web.Routing.Segments.RequestSegmentContext' from assembly 'EPiServer, Version=10.10.1.0, Culture=neutral, PublicKeyToken=8fe83dea738b45b7'.
Exception Details: System.TypeLoadException: Could not load type 'EPiServer.Web.Routing.Segments.RequestSegmentContext' from assembly 'EPiServer, Version=10.10.1.0, Culture=neutral, PublicKeyToken=8fe83dea738b45b7'.
Source Error:
Stack Trace:
[TypeLoadException: Could not load type 'EPiServer.Web.Routing.Segments.RequestSegmentContext' from assembly 'EPiServer, Version=10.10.1.0, Culture=neutral, PublicKeyToken=8fe83dea738b45b7'.]
ImageResizer.Plugins.EPiServerBlobReader.EPiServerBlobReaderPlugin.OnPostAuthorizeRequestStart(IHttpModule sender, HttpContext context) +0
ImageResizer.Configuration.RequestEventHandler.Invoke(IHttpModule sender, HttpContext context) +0
ImageResizer.Configuration.PipelineConfig.FirePostAuthorizeRequest(IHttpModule sender, HttpContext httpContext) +154
ImageResizer.InterceptModule.CheckRequest_PostAuthorizeRequest(Object sender, EventArgs e) +157
System.Web.SyncEventExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +141
System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +69
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.6.1073.0
