The configuration file has been changed by another program
We have just moved to Dxc and are experiencing some problems. From time to time this message shows:
Configuration ErrorDescription: An error occurred during the processing of a configuration file required to service this request. Please review the specific error details below and modify your configuration file appropriately.
Parser Error Message: The configuration file has been changed by another program.
Source Error:
An application error occurred on the server. The current custom error settings for this application prevent the details of the application error from being viewed remotely (for security reasons). It could, however, be viewed by browsers running on the local server machine.
Source File: D:\home\site\wwwroot\modules\_protected\EPiServer.GoogleAnalytics\EPiServerGoogleAnalytics.config    Line: 0
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.7.2053.0
It could be another .config file under _protected och web.config itself, but the message is the same.
Any suggestions?
Thanks!
/Kristoffer
#179961
Jun 27, 2017 10:55
Hi Kristoffer,
We are also have the similar issue would like to see what is causing it.  We are just restarting the site at the moment as we are in dev phase.
Cheers
#179997
Jun 28, 2017 7:43
Hi Murtaza!
is this also in the Dxc/Azure environment? We only have the problem in the Dxc.
/Kristoffer
#179998
Jun 28, 2017 8:19
There are still few modules in EPiServer Admin that can change web.config, e.g. enabling/disabling projects. Is there any activity that you do after deployment on DXC in EPiServer Admin?
#180011
Jun 28, 2017 12:08
Hi Kristoffer,
Yes we have Azure enviornment.
@K Khan, Not sure if anyone is doing that but its intermittent so very hard to figure out what causing it.
Cheers
#180104
Jun 30, 2017 1:33
We are facing the same issue on DXC.
In our case it was always the web.config file that was being changed by another program.
Although when looking at the timestamp of the file it wasn't changed.
After restarting the site it was down again after 10 minutes.
We disabled the task scheduler which seemed to fix the issue, but is not a solution.
Still looking for the real cause. Any suggestions are welcome.
Cheers,
Mark
#180108
Jun 30, 2017 8:24
Thanks Mark!
Exactlly like us, up and then down again after a while.
How do I disable the task scheduler? It is really anoying this problem!
I have a task at Epi I will let tem know that more than us has this problem. If you find a solution, please let ut know.
/Kristoffer
#180112
Jun 30, 2017 9:32
This error also started appearing for us in Azure after upgrading to one of the most recent releases of EPiServer.
The error occurs for several config files, and seems random. It often happens when releasing new updates of the site. For us, disabling the task scheduler is not an option.
#180116
Jun 30, 2017 10:17
Hi guys,
FYI we have a ticket open for this issue, and we are currently testing a possible resolution. Stay tuned for results :)
#180119
Jun 30, 2017 10:44
Same issue for us (described here). @Martin, do you have a bug number / url where we can check status?
#180153
Jun 30, 2017 13:59
@Vladimir, I don't have a bug number I'm affraid, but I have asked for this thread to be updated with progess.
#180155
Jun 30, 2017 14:09
Thank you! We're experiencing the problem in 2 azure environments for 1 project, and really curios why other projects are not affected (or when to expect problems there)
#180156
Jun 30, 2017 14:17
@Kristoffer
To disable the task scheduler you can add the following to the episerver applicationsSettings section in your web.config
<episerver>
    <applicationSettings enableScheduler="false" .....>
This is however not a solution for this problem. For us it was a workaround to keep the site running.
I would suggest waiting for Episerver's solution.
#180157
Edited, Jun 30, 2017 14:36
Hi Martin!
We have a similar issue. I reported the details here :
http://world.episerver.com/forum/developer-forum/Episerver-Commerce/Thread-Container/2017/6/cmsmembershipproviders-throwing-error-in-windows-eventlog/?pageIndex=1#reply
I came across this article https://dzone.com/articles/stronger-password-hashing-net that talks about Password hashing causing the issue. And also increase in CPU utilization. We do see a high CPU utilization after this error is encountered.
We are using "HMACSHA512" hashalgorithm. Do you see any problem in using this hashing with CMSMembershipProvider?
#180171
Jun 30, 2017 17:19
Hi, we're experiencing the same problem on our Azure environment: after restarting the Azure app service or after a new deploy, the site works for about 10 minutes, and then it throws this "The configuration file has been changed by another program" error.
Is there a solution?
#180222
Jul 03, 2017 17:17
So I got this from Episerver as a workaround:
The issue happens due to an application setting in Azure. Not only EPiServer based sites but also Sitecore based sites are facing the same issue.
A Microsoft support ticket has been created and we'll inform you if there's any update.
For now please try adding an app settings WEBSITE_DYNAMIC_CACHE and set its value of 0. Please let us know if your sites still encounter this problem.
So I did that and it look like it works for us. Hopefully there will be a Microsoft fix very soon!
/Kristoffer
#180227
Jul 03, 2017 19:33
@sapna I can't see any problems using that particular hash algorithm with the SQL Membership provider, that logic is all handled by system.web. I can't say at this point if the CPU load of one hash algorithm would provoke this issue more than others. Regardless, I think the underlying problem will be resolved soon.
#180231
Jul 03, 2017 20:35
@Kristoffer, @Martin
Thanks for the workaround, unfortunately it doesn't work for us. How it is now:
Octopus deploys a package to an azure (not DXC) site, it works for some time (5-10 minutes), and then goes down. Restarting web app from the azure portal fixes the problem.
We have
<add key="WEBSITE_DYNAMIC_CACHE" value="0" />
in our appSettings, but still see the following in the EPiServerErrors.log:
2017-07-05 12:11:17,873 [76] ERROR EPiServer.DataAbstraction.RuntimeModel.Internal.ContentTypeModelRegister: Detected change of type on property FocusedArticleLink on ListPage. Converting existing content of type EPiServer.Core.PropertyPageReference to new backing type EPiServer.Core.PropertyContentReference is not possible without loss of data. No change is commited.
2017-07-05 12:54:32,372 [42] ERROR EPiServer.Global: 1.2.5 Unhandled exception in ASP.NET
System.Configuration.ConfigurationErrorsException: The configuration file has been changed by another program. (D:\home\site\wwwroot\web.config)
   at System.Configuration.BaseConfigurationRecord.EvaluateOne(String[] keys, SectionInput input, Boolean isTrusted, FactoryRecord factoryRecord, SectionRecord sectionRecord, Object parentResult)
   at System.Configuration.BaseConfigurationRecord.Evaluate(FactoryRecord factoryRecord, SectionRecord sectionRecord, Object parentResult, Boolean getLkg, Boolean getRuntimeObject, Object& result, Object& resultRuntimeObject)
   at System.Configuration.BaseConfigurationRecord.GetSectionRecursive(String configKey, Boolean getLkg, Boolean checkPermission, Boolean getRuntimeObject, Boolean requestIsHere, Object& result, Object& resultRuntimeObject)
   at System.Configuration.BaseConfigurationRecord.GetSection(String configKey)
   at System.Web.Configuration.RuntimeConfig.GetSectionObject(String sectionName)
   at System.Web.Configuration.RuntimeConfig.GetSection(String sectionName, Type type, ResultsIndex index)
   at System.Web.Configuration.RuntimeConfig.get_Authorization()
   at System.Web.Security.UrlAuthorizationModule.CheckUrlAccessForPrincipal(String virtualPath, IPrincipal user, String verb)
   at EPiServer.Security.Internal.PathAccessChecker.HasPathAccess(String path, IPrincipal principal)
   at EPiServer.Web.Internal.DefaultDisplayChannelService.<>c.<.ctor>b__3_0(IPrincipal p)
   at EPiServer.Web.Internal.DefaultDisplayChannelService.GetActiveChannels(HttpContextBase context)
   at EPiServer.Web.Internal.TemplateResolverImplementation.ResolveCore(HttpContextBase httpContext, ContentType contentType, Type itemType, Object itemToRender, TemplateTypeCategories category, String tag)
   at EPiServer.Web.TemplateResolver.Resolve(HttpContextBase httpContext, Object itemToRender, TemplateTypeCategories templateTypeCategory, ContextMode contextMode)
   at EPiServer.Web.Mvc.Internal.ExistingActionRouteConstraint.Match(Route route, SegmentContext routingContext, String parameterName)
   at EPiServer.Web.Routing.Internal.DefaultContentRoute.MatchConstraints(SegmentContext segmentContext, HttpContextBase context)
   at EPiServer.Web.Routing.Internal.DefaultContentRoute.GetRouteData(HttpContextBase httpContext)
   at System.Web.Routing.RouteCollection.GetRouteData(HttpContextBase httpContext)
   at EPiServer.Web.Routing.RouteCollectionExtensions.HandleRouteData(RouteCollection routes, HttpContextBase context)
   at EPiServer.Global.DefaultDocumentHandling(Object sender, EventArgs e)
   at System.Web.HttpApplication.SyncEventExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute()
Do you have any other ideas/suggestions?
#180303
Jul 05, 2017 14:59
We have set WEBSITE_DYNAMIC_CACHE as an Azure variable in Azure environment, not in web.config. Don't know if that makes any difference but that is how we done it and it works just fine.
/Kristoffer
#180304
Jul 05, 2017 15:05
Thank you, @Kristoffer, my bad. Setting it in the azure portal has solved the issue!
#180306
Jul 05, 2017 15:45
#180321
Jul 06, 2017 6:35
Thanks Kristoffer Lindén, adding WEBSITE_DYNAMIC_CACHE as an Azure variable worked for me too. Dose anyone know where is this variable used and what it means, especially when you set it to 0?
#180331
Jul 06, 2017 9:43
Azure uses a feature called dynamic cache that is similar to local cache (https://github.com/MicrosoftDocs/azure-docs/blob/master/articles/app-service/app-service-local-cache.md) however, instead of caching your entire site on the VM, only the files which are requested, at least once, get cached.
Setting WEBSITE_DYNAMIC_CACHE to 0 disables this type of caching, enabeling the site can re-load the latest version of a cache file, if it needs to
#180359
Jul 07, 2017 14:34
Hello,
I had the same problems with forms.config.
Disabling the cache resolved the issue, bet there is also a 3rd option, which also works for me.
https://github.com/projectkudu/kudu/wiki/Configurable-settings#turning-on-the-dynamic-cache-feature
WEBSITE_DYNAMIC_CACHE=2 -> caches only the metadata.
Kind regards,
bob
#180543
Jul 13, 2017 17:12
New recommendation,
WEBSITE_DYNAMIC_CACHE = 0, so disabled.
Mode 2 solved my issues during deploy (arm template), but I still had issues during horzontal scaling...
#180877
Jul 31, 2017 21:06
Hi Bob,
Thanks for confirming that :)
#181273
Aug 15, 2017 11:11
