Caching images from Episerver
We have mvc projects and we load some of the images for the landing pages from epi-server using global assets folder..
The images are loaded in the html during the run time and are stored with unique identifier in
sql db. Making changes on the web-config works fine for the local but while deploying it is being
overriden by different value.
Can you guide me to find a way to cache these images?
#179231
Jun 05, 2017 22:43
Not sure I understand your problem but this is a good module to have if you need Epi assets cached downstream:
https://github.com/bjuris/EPiServer.CdnSupport
#179539
Jun 14, 2017 23:55
Thanks for it. Based on the information provided looks like that will work for version 10 and above and we have version 9. Do you have any option for it.
#179588
Jun 15, 2017 16:14
Jun 20, 2017 0:41
Thanks for support.
I tried as suggested but sitll I am not able to added the expiration.
Is there any option.
#180501
Jul 12, 2017 20:30
