How to Hide Specific EPi Properties/Tabs based on site
I am using EPiServer CMS 10.3.1 hosted in Azure Cloud. We have 2 different websites (Codebase is same but database is different) for Sweden and Finland sites. There is specific need to Finland site for some EPiServer Properties. I want ot create aTab which will only be visible to Finland site. How can we show/Hide specific properties/tab of Model in edit mode.
One of way I think is by using CustomAttrinute on Property or Tab. Can anyone let me know the solution.
//Sanket Mahimkar
#178731
May 19, 2017 11:11
Assuming you have separate editors for each site, you could use permissions to set whether a given tab is visible. You can set the permissions either in Admin -> Config -> Edit Tabs, setting the "Requires access level" value or you can set it in a code-first way by using the [RequiredAccess] attribute on your GroupName definition.
#178738
May 19, 2017 14:55
Sriram raja - Jun 10, 2020 8:17
how can we set the access for admin, editors etc... it should be as common for all the user
Thanks for reply. Edit and Delete is disabled for the Chat. But I want to hide Site Pecific EPiServer Properties as well along with Tab. How can we Hide Specific EPi Properties.
//Sanket Mahimkar
#178741
May 19, 2017 16:21
Sriram raja - Jun 10, 2020 7:21
Generally my preferred option is to put all of the restricted properties into a separate tab then apply access restrictions to that tab as this route is supported out of the box with Episerver. If you need to restrict individual properties within a given tab, you'll need to do some work in customising the UI.
As luck would have it, Linus Ekstrom wrote a blog post a while ago with a proof-of-concept solution for this kind of granular control at a property level which may well help you along the way:
http://world.episerver.com/blogs/Linus-Ekstrom/Dates/2014/5/Restricting-access-to-who-is-allowed-to-edit-a-certain-property/
#178784
May 22, 2017 14:56
