Edit mode not loading
I have just setup a new site on Everweb and after importing my pages I am getting the following error when trying to access Edit Mode. Any Ideas on how to fix ?
2017-05-16 17:22:51,142 [66] ERROR EPiServer.Global: 1.2.5 Unhandled exception in ASP.NET
System.Web.HttpException (0x80004005): Error executing child request for handler 'System.Web.Mvc.HttpHandlerUtil+ServerExecuteHttpHandlerWrapper'. ---> System.Web.HttpUnhandledException (0x80004005): Exception of type 'System.Web.HttpUnhandledException' was thrown. ---> Newtonsoft.Json.JsonSerializationException: Error getting value from 'Roots' on 'EPiServer.Forms.EditView.FormsModuleViewModel'. ---> System.NullReferenceException: Object reference not set to an instance of an object.
at EPiServer.Forms.EditView.FormsModuleViewModel.get_Roots()
at GetRoots(Object )
at Newtonsoft.Json.Serialization.DynamicValueProvider.GetValue(Object target)
at Newtonsoft.Json.Serialization.JsonSerializerInternalWriter.CalculatePropertyValues(JsonWriter writer, Object value, JsonContainerContract contract, JsonProperty member, JsonProperty property, JsonContract& memberContract, Object& memberValue)
at Newtonsoft.Json.Serialization.JsonSerializerInternalWriter.SerializeObject(JsonWriter writer, Object value, JsonObjectContract contract, JsonProperty member, JsonContainerContract collectionContract, JsonProperty containerProperty)
at Newtonsoft.Json.Serialization.JsonSerializerInternalWriter.SerializeList(JsonWriter writer, IEnumerable values, JsonArrayContract contract, JsonProperty member, JsonContainerContract collectionContract, JsonProperty containerProperty)
at Newtonsoft.Json.Serialization.JsonSerializerInternalWriter.Serialize(JsonWriter jsonWriter, Object value, Type objectType)
at Newtonsoft.Json.JsonSerializer.SerializeInternal(JsonWriter jsonWriter, Object value, Type objectType)
at EPiServer.Framework.Serialization.Json.Internal.JsonObjectSerializer.Serialize(TextWriter textWriter, Object value)
at EPiServer.Shell.Web.Mvc.Html.ScriptExtensions.SerializeObject(HtmlHelper html, Object value, String contentType)
at ASP.episerver_shell_views_shared_bootstrapper_aspx.__Render__control5(HtmlTextWriter __w, Control parameterContainer) in http://server/EPiServer/Shell/Views/Shared/Bootstrapper.aspx:line 58
at System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children)
at System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter)
at ASP.episerver_shell_views_shared_sleek_master.__Render__control1(HtmlTextWriter __w, Control parameterContainer) in http://server/EPiServer/Shell/Views/Shared/Sleek.Master:line 30
at System.Web.Mvc.ViewPage.Render(HtmlTextWriter writer)
at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
at System.Web.UI.Page.HandleError(Exception e)
at System.Web.UI.Page.ProcessRequest(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
at System.Web.UI.Page.ProcessRequest()
at System.Web.UI.Page.ProcessRequest(HttpContext context)
at ASP.episerver_shell_views_shared_bootstrapper_aspx.ProcessRequest(HttpContext context) in c:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\43e4c684\5b301aff\App_Web_kkjk0e02.0.cs:line 0
at System.Web.Mvc.HttpHandlerUtil.ServerExecuteHttpHandlerWrapper.<>c__DisplayClass4.b__3()
at System.Web.Mvc.HttpHandlerUtil.ServerExecuteHttpHandlerWrapper.Wrap[TResult](Func`1 func)
at System.Web.HttpServerUtility.ExecuteInternal(IHttpHandler handler, TextWriter writer, Boolean preserveForm, Boolean setPreviousPage, VirtualPath path, VirtualPath filePath, String physPath, Exception error, String queryStringOverride)
at System.Web.HttpServerUtility.Execute(IHttpHandler handler, TextWriter writer, Boolean preserveForm, Boolean setPreviousPage)
at System.Web.HttpServerUtility.Execute(IHttpHandler handler, TextWriter writer, Boolean preserveForm)
at System.Web.Mvc.ViewPage.RenderView(ViewContext viewContext)
at System.Web.Mvc.ViewResultBase.ExecuteResult(ControllerContext context)
at System.Web.Mvc.ControllerActionInvoker.InvokeActionResultFilterRecursive(IList`1 filters, Int32 filterIndex, ResultExecutingContext preContext, ControllerContext controllerContext, ActionResult actionResult)
at System.Web.Mvc.ControllerActionInvoker.InvokeActionResultWithFilters(ControllerContext controllerContext, IList`1 filters, ActionResult actionResult)
at System.Web.Mvc.ControllerActionInvoker.InvokeAction(ControllerContext controllerContext, String actionName)
at System.Web.Mvc.Controller.ExecuteCore()
at System.Web.Mvc.ControllerBase.Execute(RequestContext requestContext)
at EPiServer.Shell.Web.Mvc.ModuleMvcHandler.ProcessController(IController controller)
at EPiServer.Shell.Web.Mvc.ModuleMvcHandler.BeginProcessRequest(HttpContextBase httpContext, AsyncCallback callback, Object state)
#178649
May 16, 2017 17:33
How did you import your pages?
#178659
May 16, 2017 22:54
Hi Minesh,
We are seeing the same behaviour.  Did you ever resolve this?
Adam
#196142
Aug 20, 2018 13:06
