Issue with Structuremap
I am running into a structure map issue i believe and not sure how to solve it appropriately.  Has anyone ran into this.
Value cannot be null.
Parameter name: httpContext
Exception Details: System.ArgumentNullException: Value cannot be null.
Source Error:
[No relevant source lines]
Source File: c:\Windows\Microsoft.NET\Framework\v4.0.30319\Temporary ASP.NET Files\root\feb9e478\51c2f68d\App_global.asax.v8jyifn3.0.cs    Line: 0
Stack Trace:
[ArgumentNullException: Value cannot be null.
Parameter name: httpContext]
   System.Web.HttpContextWrapper..ctor(HttpContext httpContext) +9787473
   lambda_method(Closure , IBuildSession , IContext ) +133
[StructureMapBuildException: Failure while building 'Lambda: new HttpContextWrapper(HttpContext.Current)', check the inner exception for details
1.) Lambda: new HttpContextWrapper(HttpContext.Current)
2.) Instance of System.Web.HttpContextBase (System.Web.HttpContextWrapper)
3.) new ExtensibleMetadataProvider(*Default of MetadataHandlerRegistry*, *Default of LocalizationService*, *Default of HttpContextBase*)
4.) EPiServer.Shell.ObjectEditing.ExtensibleMetadataProvider
5.) Instance of EPiServer.Shell.ObjectEditing.ExtensibleMetadataProvider
6.) new ContentDataMetadataProvider(*Default of MetadataHandlerRegistry*, *Default of ServiceAccessor*, *Default of ITabDefinitionRepository*, *Default of ContentTypeModelRepository*, *Default of ContentMetaDataPropertiesInjector*, *Default of IMetaDataResolver*, *Default of IContentLoader*, *Default of LocalizationService*, *Default of ExtensibleMetadataProvider*, *Default of ServiceAccessor*)
7.) EPiServer.Cms.Shell.UI.Internal.ContentDataMetadataProvider
8.) Instance of EPiServer.Cms.Shell.UI.Internal.ContentDataMetadataProvider
9.) Container.GetInstance(EPiServer.Cms.Shell.UI.Internal.ContentDataMetadataProvider)
   lambda_method(Closure , IBuildSession , IContext ) +937
   StructureMap.Building.BuildPlan.Build(IBuildSession session, IContext context) in c:\BuildAgent\work\a395dbde6b793293\src\StructureMap\Building\BuildPlan.cs:151
   StructureMap.BuildSession.BuildNewInSession(Type pluginType, Instance instance) in c:\BuildAgent\work\a395dbde6b793293\src\StructureMap\BuildSession.cs:114
   StructureMap.Pipeline.NulloTransientCache.Get(Type pluginType, Instance instance, IBuildSession session) in c:\BuildAgent\work\a395dbde6b793293\src\StructureMap\Pipeline\NulloTransientCache.cs:28
   StructureMap.BuildSession.ResolveFromLifecycle(Type pluginType, Instance instance) in c:\BuildAgent\work\a395dbde6b793293\src\StructureMap\BuildSession.cs:103
   StructureMap.SessionCache.GetObject(Type pluginType, Instance instance, ILifecycle lifecycle) in c:\BuildAgent\work\a395dbde6b793293\src\StructureMap\SessionCache.cs:93
   StructureMap.SessionCache.GetDefault(Type pluginType, IPipelineGraph pipelineGraph) in c:\BuildAgent\work\a395dbde6b793293\src\StructureMap\SessionCache.cs:68
   StructureMap.Container.GetInstance(Type pluginType) in c:\BuildAgent\work\a395dbde6b793293\src\StructureMap\Container.cs:337
   EPiServer.ServiceLocation.StructureMapServiceLocator.DoGetInstance(Type serviceType, String key) +40
   EPiServer.ServiceLocation.ServiceLocatorImplBase.GetInstance(Type serviceType, String key) +42
[ActivationException: Activation error occurred while trying to get instance of type ContentDataMetadataProvider, key ""]
   EPiServer.ServiceLocation.ServiceLocatorImplBase.GetInstance(Type serviceType, String key) +101
   EPiServer.ServiceLocation.ServiceLocatorImplBase.GetInstance() +60
   EPiServer.Cms.Shell.<>c__DisplayClass2_0.b__0() +93
   System.Threading.Tasks.Task.InnerInvoke() +73
   System.Threading.Tasks.Task.Execute() +51
[AggregateException: One or more errors occurred.]
   System.Threading.Tasks.Task.ThrowIfExceptional(Boolean includeTaskCanceledExceptions) +4126993
   System.Threading.Tasks.Task.Wait(Int32 millisecondsTimeout, CancellationToken cancellationToken) +12256921
   EPiServer.Cms.Shell.<>c__DisplayClass2_0.b__1(Object sender, EventArgs args) +15
   System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor) +0
   System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments) +160
   System.Delegate.DynamicInvokeImpl(Object[] args) +117
   EPiServer.Framework.Initialization.InitializationEngine.OnInitComplete() +195
   EPiServer.Framework.Initialization.InitializationEngine.ExecuteTransition(Boolean continueTransitions) +164
   EPiServer.Framework.Initialization.InitializationEngine.Initialize() +40
   EPiServer.Framework.Initialization.<>c.b__7_0(InitializationEngine e) +9
   EPiServer.Framework.Initialization.InitializationModule.EngineExecute(HostType hostType, Action`1 engineAction) +261
   EPiServer.Framework.Initialization.InitializationModule.FrameworkInitialization(HostType hostType) +170
   EPiServer.Global..ctor() +76
   Frigidaire.Web.Global..ctor() +29
   ASP.global_asax..ctor() in c:\Windows\Microsoft.NET\Framework\v4.0.30319\Temporary ASP.NET Files\root\feb9e478\51c2f68d\App_global.asax.v8jyifn3.0.cs:0
   System.RuntimeTypeHandle.CreateInstance(RuntimeType type, Boolean publicOnly, Boolean noCheck, Boolean& canBeCached, RuntimeMethodHandleInternal& ctor, Boolean& bNeedSecurityCheck) +0
   System.RuntimeType.CreateInstanceSlow(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache, StackCrawlMark& stackMark) +114
   System.RuntimeType.CreateInstanceDefaultCtor(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache, StackCrawlMark& stackMark) +232
   System.Activator.CreateInstance(Type type, Boolean nonPublic) +83
   System.RuntimeType.CreateInstanceImpl(BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes, StackCrawlMark& stackMark) +1088
   System.Activator.CreateInstance(Type type, BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes) +128
   System.Activator.CreateInstance(Type type, BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture) +20
   System.Web.HttpRuntime.CreateNonPublicInstance(Type type, Object[] args) +60
   System.Web.HttpApplicationFactory.GetSpecialApplicationInstance(IntPtr appContext, HttpContext context) +260
   System.Web.Hosting.PipelineRuntime.InitializeApplication(IntPtr appContext) +296
   System.Web.HttpRuntime.FirstRequestInit(HttpContext context) +9963380
   System.Web.HttpRuntime.EnsureFirstRequestInit(HttpContext context) +101
   System.Web.HttpRuntime.ProcessRequestNotificationPrivate(IIS7WorkerRequest wr, HttpContext context) +254
I am sure i am missing something but is there a way to log what exacly it is trying to call.
#175864
Mar 05, 2017 0:13
