How to export global blocks from Episerver CMS 6
When I export a page from Episerver CMS 6 which has a global block, the page is exported but it does not have the global block.
Can anyone please help me with this or share the steps that I can follow to export global blocks ?
Regards,
Pranjal
#176688
Mar 23, 2017 16:07
Pranjal,
On the Export Data view, are you checking Export files that the pages link to?
#176692
Mar 23, 2017 17:47
Hi Bob,
I had selected the option to export files that the page links to, but its still not exporting the global blocks. Any other steps that I might be missing ?
Pranjal
#176735
Mar 24, 2017 10:32
@Pranjal are you sure about the version of CMS you are using, I think CMS 6 does not have blocks concept.
regarding your problem, I would guess you are using CMS 7 and I think you are missing the block type for the global blocks.
#177234
Apr 05, 2017 19:03
Hi Duke,
We had implemented composer blocks using PageTypeBuilder. However, I found the solution the the problem. There is a repository where all the composer blocks are stored. I had to migrate that repository and global blocks started appearing.
Thanks for your responses.
Regads,
Pranjal
#178579
May 15, 2017 12:48
