Error logs get drained by Ambiguous match find for Episerver Find
After swithing between branch'es I get this error all the time in my loggs and I have no clue on how to find where it has gone wrong.
ERROR [] EPiServer.Find.Cms.ContentEventIndexer System.Reflection.AmbiguousMatchException: Ambiguous match found.
   at System.RuntimeType.GetPropertyImpl(String name, BindingFlags bindingAttr, Binder binder, Type returnType, Type[] types, ParameterModifier[] modifiers)
   at System.Type.GetProperty(String name)
   at EPiServer.Find.Cms.ContentExtensions.d__22.MoveNext()
   at System.Linq.Buffer`1..ctor(IEnumerable`1 source)
   at System.Linq.OrderedEnumerable`1.d__1.MoveNext()
   at System.Linq.Enumerable.WhereSelectEnumerableIterator`2.MoveNext()
   at System.Linq.Enumerable.WhereEnumerableIterator`1.MoveNext()
   at System.Linq.Enumerable.ToArray[TSource](IEnumerable`1 source)
   at EPiServer.Find.Cms.ContentExtensions.SearchText(IContentData contentData)
   at EPiServer.Find.DelegateValueProvider`2.GetValue(Object target)
   at Newtonsoft.Json.Serialization.JsonSerializerInternalWriter.CalculatePropertyValues(JsonWriter writer, Object value, JsonContainerContract contract, JsonProperty member, JsonProperty property, JsonContract& memberContract, Object& memberValue)
   at Newtonsoft.Json.Serialization.JsonSerializerInternalWriter.SerializeObject(JsonWriter writer, Object value, JsonObjectContract contract, JsonProperty member, JsonContainerContract collectionContract, JsonProperty containerProperty)
   at Newtonsoft.Json.Serialization.JsonSerializerInternalWriter.Serialize(JsonWriter jsonWriter, Object value, Type objectType)
   at EPiServer.Find.Api.BulkActionConverter.WriteJson(JsonWriter writer, Object value, JsonSerializer serializer)
   at Newtonsoft.Json.Serialization.JsonSerializerInternalWriter.SerializeConvertable(JsonWriter writer, JsonConverter converter, Object value, JsonContract contract, JsonContainerContract collectionContract, JsonProperty containerProperty)
   at Newtonsoft.Json.JsonSerializer.SerializeInternal(JsonWriter jsonWriter, Object value, Type objectType)
   at EPiServer.Find.Json.Serializer.SerializeToTextWriter(JsonSerializer serializer, Object value, TextWriter textWriter)
   at EPiServer.Find.Json.Serializer.SerializeObjectsToJsonRequest(JsonSerializer serializer, IJsonRequest jsonRequest, IEnumerable values)
   at EPiServer.Find.Api.BulkCommand.Execute()
   at EPiServer.Find.Cms.ContentIndexer.IndexWithRetry(IContent[] contents, Int32 maxRetries)
   at EPiServer.Find.Cms.ContentIndexer.Index(IEnumerable`1 content, IndexOptions options)
   at EPiServer.Find.Cms.ContentEventIndexer.Index(IEnumerable`1 contentLinks)
   at EPiServer.Find.Cms.ContentEventIndexer.Sync(IEnumerable`1 contentToIndex, HashSet`1 contentToIndexSet, Func`1 index)
   at EPiServer.Find.Cms.ContentEventIndexer.IndexPageQueue(IEnumerable`1 contentToIndex)
   at EPiServer.Find.Cms.ContentEventIndexer.IndexPageQueue()
 - An exception occurred while indexing (IContent). Ambiguous match found..
#176310
Mar 15, 2017 15:01
Hi Henrik,
The reflection is ambiguous of a property. You may have a pagemodel with inherit abract property, put [JsonIgnore] on the inherited/abstract one.
We had it on DynamicProperties (legacy)
Regards!
#176312
Mar 15, 2017 15:25
Hmm, I have the same issue in my project and it just started to fill up the logs (App Insights).
So this has to do with inheritance of abstract classes? Anyway, I'm investigating this now.
I will get back to this thread if I find a solution or solve the problem.
#176343
Mar 16, 2017 13:53
Yes, it might by a normal override of properity on a page model, when missing the new key, check your warnings in VS compile. The reflector isn't that clever...
#176344
Mar 16, 2017 14:04
