Issue with permanentlinkstore
var url = new UrlBuilder(slide.Href);
           if (PermanentLinkMapStore.ToMapped(url))
                var cr = PermanentLinkUtility.GetContentReference(url);
The above code gives warning that PermanentLinkUtility.GetContentReference(UrlBuilder)' is obsolete: 'This method only supports classic/mapped url's which are no longer used since 8.0 - use PermanentLinkUtility.GetGuid(url) to get the unique ID from an URL'
When i try to change if condition like
if (PermanentLinkUtility.GetGuid(url))
Then it gives error Cannot convert EpiServer.UrlBuilder to string
What is alternative to this?
I am on Episerver 9.2
#174760
Feb 03, 2017 12:04
What about using UrlResolver
var content = UrlResolver.Current.Route(new UrlBuilder(slide.Href));
return content != null ? content.ContentLink : ContentReference.EmptyReference;
#174777
Feb 03, 2017 15:37
I am getting error Cannot implicitly convert type Episerver.core.contentreference to system.collection.genericelist<episerver.core.pagedata>
on this line
#174784
Feb 03, 2017 16:05
My whole code is like this
public static List<PageData> ToPages(this LinkItemCollection linkItemCollection)
            var pages = new List<PageData>();
            if (linkItemCollection == null) return pages;
            foreach (LinkItem linkItem in linkItemCollection)
                string linkUrl;
                if (!PermanentLinkMapStore.TryToMapped(linkItem.Href, out linkUrl))
                    continue;
                if (string.IsNullOrEmpty(linkUrl))
                    continue;
                var pageReference = PageReference.ParseUrl(linkUrl);
                if (PageReference.IsNullOrEmpty(pageReference))
                    continue;
                pages.Add(DataFactory.Instance.GetPage((pageReference)));
            return pages;
#174785
Feb 03, 2017 16:11
Try this
public static List<T> ToPages<T>(this LinkItemCollection linkItemCollection) where T : PageData
var pages = new List<T>();
if (linkItemCollection == null || linkItemCollection.Count.Equals(0))
return new List<T>();
var urlResolver = ServiceLocator.Current.GetInstance<UrlResolver>();
foreach (var linkItem in linkItemCollection)
if (String.IsNullOrEmpty(linkItem.Href))
continue;
var urlBuilder = new UrlBuilder(linkItem.Href);
var page = urlResolver.Route(urlBuilder) as T;
if (page != null && (!page.IsDeleted && page.CheckPublishedStatus(PagePublishedStatus.Published)))
pages.Add(page);
#174787
Feb 03, 2017 16:17
I get error
Error CS0161 'LinkCollectionExtentions.ToPages<T>(LinkItemCollection)': not all code paths return a value
Looks like we are not returning anything
#174788
Feb 03, 2017 16:26
ok just returned pages and got rid of error. Will try and let you know
#174789
Feb 03, 2017 16:42
My other class referencing this is throwing error now.
  protected override void OnLoad(EventArgs e)
            base.OnLoad(e);
            var lic = Persons.Value as LinkItemCollection;
            repeatPerson.DataSource = lic.ToPages(); // this code throws error
            repeatPerson.DataBind();
Any idea?
#174790
Feb 03, 2017 16:56
I think you need to do like this
 repeatPerson.DataSource = lic.ToPages<PageData>(); // this code throws error
#174798
Feb 03, 2017 19:11
Just last one thing. What is replacement for below
 var url = new UrlBuilder(linkItem.Href);
                if (PermanentLinkMapStore.ToMapped(url)) //get warning here
#174800
Feb 03, 2017 22:41
This would be the equivalent
Let urlresolver make the mapping between internal objekt and inernal in a linklist.
#174807
Feb 05, 2017 1:09
Here is my code where i tried to use your suggestion. how we make use of page variable to replace permanentlinkmapstore?
protected string Mymethod(object dataItem)
            var linkItem = dataItem as LinkItem;
            if (linkItem == null) return "";
            try
                var page = urlResolver.Route(url) as PageData;
                    var success = EPiServer.Global.UrlRewriteProvider.ConvertToExternal(url, null, Encoding.UTF8);
                    return url.ToString();
                return linkItem.Href;
            catch (Exception)
                //some logic            }
#174808
Feb 05, 2017 10:54
Try this
			var content = UrlResolver.Current.Route(new UrlBuilder(linkItem.Href));
            return content != null ? UrlResolver.Current.GetUrl(content.ContentLink) : linkItem.Href;
#174815
Feb 06, 2017 7:26
Thanks a lot. How to mark as answer? I dont see any option. It seem only i mark my replies are answers.
#174816
Feb 06, 2017 8:22
