hi,
I have an issue with some code i am writing that uses the dynamic data store. In the code i have 2 objects registration category and registration statistic. One of registration statistic's properties is registration category - see below for class definitions. when i delete an instance of registration statistic it also deletes from the database the referenced instance of registration category - this is not what i expected it to do. from testing this morning i have found that the dds will not delete a registration category if it is referenced by another registration statistic, so it seems to be checking if the referenced object is used elsewhere before deleting it.
can anyone confirm if this is how the dds normally works? is there a way to tell the store to not delete referenced objects like this?
thanks in advance
Sam
classes:
[Pasting files is not allowed]
