Cannot delete project
I don't know if I'm dumb or not, but I find no way of deleting a project I created, the options are greyed out:
https://img42.com/4RF4n
https://img42.com/lKpU4
Do I need to create some ProjectAdministrator-group or something?
#175598
Edited, Feb 23, 2017 21:53
Nope, not needed, somethings wrong, check in the F12 panel if you have any red (500) request?
#175606
Feb 24, 2017 7:42
The solution I'm working at, have the same problem (latest epi + commerce).
No 500 error messages here
#175607
Feb 24, 2017 7:47
Nope, no 500 Server errors here either. Running latest version as well. Let me pop up a pure Alloy EPi 10 latest version. To see what happens
#175614
Feb 24, 2017 9:41
Ok, so i've installed EPi10 and upgraded it to the exact same version. And it works there.
So I did some more digging, it actually works in my development environment, the optioned are not greyed out there. It doesn't work in any of the testing environments. Which are all hosted in the Azure Cloud and EPiServer DXC Cloud.
So I investigated any configuration differences, and made the cloud environment as close as identical as possible with debug activated and customErrors=Off and similar - But with no change, still can't delete or rename projects when the application is deployed to Azure Website.
#175617
Feb 24, 2017 10:45
Just for information, mine doesn't work in development or testing (haven't tested in production). Not hosted in the cloud :)
#175619
Feb 24, 2017 11:19
Hi Magnus,
Is there any more info I can get on this one?? I can't understand in anyway why it is happening. Any logs, more info will be appriciated.
#175694
Feb 27, 2017 16:14
I don't have any more info regarding this right now, my plan was to install an Alloy EPi version 10 site into the Azure, but lack of time has stopped me from doing that.
#175717
Edited, Feb 28, 2017 11:04
I think I know whats wrong. It have something to do with the compressed JS, because if I add EPiServer.CMS.UI.Sources to the project and <clientResources debug="true" /> to the <episerver.framework> section then everything works as expected.
Can you try that Magnus?
#175722
Feb 28, 2017 13:41
We have the same problem: projects can be deleted in development environment with <clientResources debug="true" />, but not on production/test with minimized Episerver js. Our EPiServer.CMS.UI version is 10.4.0.
#176041
Mar 08, 2017 11:09
Do you have any add-ons installed? We're not able to reproduce with a clean install.
When you say "development environment", do you mean locally on your machine or hosted somewhere (Azure etc)?
#176071
Edited, Mar 09, 2017 10:05
We have plenty of add-ons installed: Commerce, Find, Forms, Language Manager, Google Analytics, LanguageWire etc :) Maybe others have less. I can try to remove simple add-ons like Forms, LM, GA and LW and see if it helps. Dev environment is my local machine, but I think the only difference is <clientResources debug="true" /> option.
#176084
Mar 09, 2017 12:50
We're using the following add-ons:
  • LanguageManager
  • Find
  • Forms
  • Visitorgroup-pack
We do not have the <clientResources debug="true" /> set in our development environment, and we can edit projects locally. (IIS local server 10.0 on Windows 10)
And we do not inject the EPiServer.CMS.UI.Sources specifically either, but mayby some debug="true" flags loads them anyway.
We the following Security providers, and session-providers that support cloud:
  • System.Web.Providers.DefaultRoleProvider
  • System.Web.Providers.DefaultMembershipProvider
  • System.Web.Providers.DefaultProfileProvider
We do use gZip compressions, static caching, and output cache in our test and production environment, but disabled in our development environment (local).
#176085
Mar 09, 2017 13:00
We have
LanguageManager
Forms
Find
Find commerce
Menupin
Dynamic multisearch
Social
VisitorGroup
robotstxt handler
bvnetwork 404handler
optimizily
Geta
-sitemap (and for commerce)
-FontThumbnail (this was added later so this is not the culprint at least)
-extensions
And probably some more I have forgot at the moment
#176090
Mar 09, 2017 14:24
Hi everyone.
I've managed to reproduce this now and it seems to be related to the LanguageManager addon.
Could anyone of you verify this by removing the addon and see if that helps?
#176117
Mar 10, 2017 9:37
Confirmed for my solution at least :)
#176121
Mar 10, 2017 9:43
Great to hear Sebastian! Did you remember to remove the <clientResources debug="true" /> from your config?
#176123
Mar 10, 2017 9:46
I added the addon back and then I couldn't delete project again ;)
#176126
Mar 10, 2017 10:13
Thanks! I've seen the same on two additional environments now so I think we can say that we've found what causes the issue.
I'll make sure that the team responsible for the LanguageManager addon is notified.
#176127
Mar 10, 2017 10:17
Thanks for the feedback everyone. It's now reported as a bug in the LanguageManager addon with id: LM-51
#176133
Mar 10, 2017 10:42
The fix for LM-51 was released today in update 156.
#176805
Mar 27, 2017 20:32
