I've created a custom property that uses TinyMce. I got it all working in EPi 10. Now I'm implementing the solution in a EPi 9 site and TinyMce can't find the language-files. Searching for http://localhost:17000/to/UI/CMS/9.6.0.0/ClientResources/Editor/tiny_mce/langs/sv.js
In EPi 10 I solved this by adding the file to C:\Projects\MyTestSite\modules\_protected\CMS\10.0.2.0\ClientResources\Editor\tiny_mce\langs\sv.js
This does not work on my EPi 9 site. Tried to find differences in my config-files, but can't find anything relevant.
The best solution would be to NOT add anything to the _protected folder, but instead point out the language-file through a setting. Seems to be some EPiServer setting. Is this possible?
My custom property looks like:
and then I initialize TinyMce with:
Tried without success: TinyMce has the setting language_url, but I think that's only for TinyMce4.x (and EPiServer uses 3.x).
