How to upgrade from 10.8 to 11.3 frame work????
Hi Guys,
    I want to upgrade the EPIServer CMS Application from 10.8 to 11.3,can anyone help out of this.
Kartheek.
#186616
Dec 27, 2017 10:50
Hi Caric,
    Thanks for your reply and time consideration,can you explain bit,is there any chance to upgrade with out using nuget,package maagers console???
Kartheek
#186620
Edited, Dec 27, 2017 14:18
<p>Episerver assemblies are distributed&nbsp;as NuGet packages. So you'll have to upgrade epi by using either Package Manager Console or GUI tool (in Visual Studio, select Tools &gt; NuGet Package Manager &gt; Manage NuGet Packages for Solution...).</p> <p>Before doing that, make sure you have an EPiServer NuGet feed in the list of available package sources (Tools &gt; NuGet Package Manager &gt; Package Manager Settings, select Package Sources and add&nbsp;<a href="http://nuget.episerver.com/feed/packages.svc/">http://nuget.episerver.com/feed/packages.svc/</a>)</p>
#186621
Dec 27, 2017 14:43
No Caric,i  want to upgrade using .DLL's only i.e:-i pasted the new version(11.3) .dll's in older version(10.8) EPIServer application and set visual studio entity framework=4.6.1,than the applicaton build successfully but when i run the application i get the error from web.config file at  line number 11 i.e:
Configuration Error Parser Error Message: An error occurred creating the configuration section handler for episerver.framework: Could not load type 'EPiServer.Framework.Configuration.EPiServerFrameworkSection' from assembly 'EPiServer.Framework'.
Source Error:
Line 9:      <section name="entityFramework" type="System.Data.Entity.Internal.ConfigFile.EntityFrameworkSection, EntityFramework, Version=6.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" requirePermission="false"/>
Line 10:     <section name="episerver" type="EPiServer.Configuration.EPiServerSection, EPiServer.Configuration"/>
Line 11:     <section name="episerver.framework" type="EPiServer.Framework.Configuration.EPiServerFrameworkSection, EPiServer.Framework" restartOnExternalChanges="true"/>
Line 12:     <section name="episerver.baseLibrary" allowDefinition="MachineToApplication" allowLocation="false" type="EPiServer.BaseLibrary.ConfigurationHandler,EPiServer.BaseLibrary"/>
Line 13:     <section name="episerver.search" type="EPiServer.Search.Configuration.SearchSection, EPiServer.ApplicationModules"/>
#186625
Edited, Dec 28, 2017 5:31
<p>Hi, Kartheek,</p> <p>That's really not a great idea.&nbsp;You would have quite a lot of headache upgrading without nuget packages. You would need to know which exact version of every single dll would work with the rest of the dlls.</p> <p>Even if you have a mess in your project, it's better if you delete&nbsp;your bin folder and install all packages.</p> <p>Why would you want to skip the normal nuget upgrade process?</p>
#186628
Dec 28, 2017 10:53
Hi,Marija,
     Thanks for your response and i'd try to upgrade using nuget and package manager console
Kartheek.
#186629
Dec 28, 2017 11:26
i upgrade from 10.8 to 11.3 using Nuget and successfully build the solution also but when i run the application i get this error,can anyone help me out of this.
Error:-
While loading .NET types from "WorikingEpiSite" the following error(s) was reported:
    - System.TypeLoadException: Could not load type 'EPiServer.Global' from assembly 'EPiServer, Version=11.3.0.0, Culture=neutral, PublicKeyToken=8fe83dea738b45b7'.
    - System.TypeLoadException: Could not load type 'EPiServer.Web.Mvc.BlockController`1' from assembly 'EPiServer, Version=11.3.0.0, Culture=neutral, PublicKeyToken=8fe83dea738b45b7'.
    - System.TypeLoadException: Could not load type 'EPiServer.Web.Mvc.PageController`1' from assembly 'EPiServer, Version=11.3.0.0, Culture=neutral, PublicKeyToken=8fe83dea738b45b7'.
#186650
Edited, Dec 29, 2017 6:22
<p>You need to install episerver.cms.aspnet package. And make sure if you are using 3rd party assemblies they are upgraded to a version which supports CMS 11</p>
#186652
Dec 29, 2017 9:14
