409 conflict creating block
Hi! I'm having an issue creating a certain block of mine. It occurs both in production and in development and also running version 10 and the latest version.
When creating the block I get an error in my browser console stating a 409 conflict error. It happens approx 80 % of the times trying to create the block.
  1. Request URL: http://mydomain/EPiServer/cms/Stores/contentdata/
  2. Request Method: POST
  3. Status Code: 409 Conflict
The request payload:
  "name": "New Blockaaaa",
  "parentLink": "5_76891",
  "contentTypeId": 46,
  "properties": {
    "icategorizable_category": [],
    "image": "/link/8690b853be154572967feb02028fef05.aspx",
    "name": "xx",
    "title": "xxxxx",
    "mainBody": "
asdfasfd
", "phone": "xxx", "email": "xxxxx" }, "createAsLocalAsset": true, "autoPublish": true }
I can't see anything strange with the block other than that it inherits from another blocktype. But thats alright isn't it?
#186330
Dec 18, 2017 9:11
+1. We are experiencing the same issue.
#186675
Jan 02, 2018 10:59
Did you solve it? I am experiencing the same issue.
#191036
Apr 19, 2018 12:02
Can you post the code?
#191092
Apr 19, 2018 23:18
Please review this knowledge base and let me know if it helps
https://support.episerver.com/hc/en-us/articles/360002910312-409-conflict-Creating-page-block
#191098
Apr 20, 2018 5:49
I am experiencing the same issue. (Version 10)
I have reviewed the solution suggested in the link above https://support.episerver.com/hc/en-us/articles/360002910312-409-conflict-Creating-page-block and can confirm this occurs even when with existingResponse attribute is set to
   existingResponse="PassThrough" />
or it's not added.
Here are some more details:
  • issue seems to occur for certain blocks only
    • blocks have required properties and non-required properties
    • most properties are culturespecific
  • issue occurs only when user tries to create these blocks from ContentArea
    • issue never occurs when blocks are created on the Assets panel
    • Response is
      • message: "Unable to load /secui/cms/Stores/contentdata/ status: 409"
      • url:"/secui/cms/Stores/contentdata/"
      • responseText: "The page was not displayed because there was a conflict."
      • status:409
      • statusText:"Conflict"
#192624
May 21, 2018 18:29
We had a selection factory which timed out causing a 409. We checked the logging and got an Unexpected error when requesting  model accessor which pointed us to the problem in the stack trace.
I would check the logs for MetadataStore for any hints of what goes wrong.
In our case:
Unexpected error when requesting model accessor for EPiServer.Core.ContentData with parameter {"parentLink":"117","contentTypeId":24} System.Net.WebException: The operation has timed out at Sys (..)
EPiServer.Shell.UI.Rest.MetadataStore
ERROR
20
#194553
Edited, Jun 25, 2018 13:28
If you are using a version earlier than 11.8 this can be caused by a custom validator which fires a validation message, but is not displayed due to bug Bug - CMS-11522
Read more on https://world.episerver.com/support/Bug-list/bug/CMS-11522
#198498
Oct 30, 2018 5:25
I have recently started to see this error message and am on EPiServer.CMS.UI 11.16.0.
#206214
Aug 07, 2019 13:23
Tomas Hensrud Gulla
We are seeing it on EPiServer.CMS.UI 11.18.0. It only happens when creating a block with custom validator from the ContentArea. When creating from assets pane, it works.
Same issue as described here: https://world.episerver.com/support/Bug-list/bug/CMS-11522
#209034
Edited, Nov 06, 2019 13:17
