Remove Forms-tab form the Asset pane?
Can I somehow remove the Forms-tab form the Asset pane? Forms are blocks, so it's not needed.
#185433
Nov 20, 2017 10:17
Hi Jouni
I did not research the key for Forms but this post should point you in the right direction:
https://www.david-tec.com/2016/05/remove-episerver-ui-components-for-certain-editors/
David
#185436
Nov 20, 2017 12:37
Not an answer, but I do agree that this UI is a bit messy.
#185437
Nov 20, 2017 12:46
Hey,
This web.config change removes it:
<episerver.shell>
    <viewManager>
      <views>
        <add name="/episerver/cms/home">
          <settings>
            <add name="RemoveFormComponent" transformationType="Remove" definitionName="EPiServer.Forms.Components.FormsComponent" plugInArea="/episerver/cms/assets/defaultgroup" />
          </settings>
        </add>
      </views>
    </viewManager>
  </episerver.shell>
I agree it's a bit annoying :D
#185622
Nov 27, 2017 22:34
Thanks Marija!
What Forms versions does that configuration support? I quickly tested with Forms 4.6.1, but with no luck. What version do you use?
#185758
Dec 01, 2017 5:27
Hey Jouni,
Trying going to My settings -> Display options -> Reset views. Does it work when you do that?
BR,
Marija
#185772
Dec 01, 2017 9:40
Hi Marija,
I found that in this version the namespace is EPiServer.Forms.EditView.Components.FormsComponent. After changing it (and resetting the views) the Forms-tab is gone :)
    <viewManager>
      <views>
          <settings>
            <add name="RemoveFormComponent" transformationType="Remove" definitionName="EPiServer.Forms.EditView.Components.FormsComponent" plugInArea="/episerver/cms/assets/defaultgroup" />
          </settings>
        </add>
      </views>
    </viewManager>
#185809
Dec 01, 2017 17:48
