Membership.ValidateUser Epi 10.10.1 always returns false
I'm using default member and role provider setttings and the ValidateUser method always returns false. The desired result is a simple custom login page using the logic below. All data, inluding username and password are being passed to the controller, as you would expect, but I always get a return value of false. I have attempted to switch the multiplex provider or simply the SQL provider, but they simply result in an error on post submission.
[System.Web.Mvc.HttpPost]
        [ValidateAntiForgeryToken]
        public ActionResult Post(LoginPage currentPage, [FromBody] LoginFormPostbackData LoginPostbackData)
            var model = new LoginModel(currentPage);
            var isValid = Membership.ValidateUser(LoginPostbackData.Username, LoginPostbackData.Password);
            var isUser = Membership.GetUser(LoginPostbackData.Username);
            if (isValid)
                var redirectUrl = GetRedirectUrl(LoginPostbackData.ReturnUrl);
                FormsAuthentication.SetAuthCookie(LoginPostbackData.Username, LoginPostbackData.RememberMe);
                return Redirect(redirectUrl); //Important to redirect after login to be sure cookies etc are set.
            } else
                MembershipUser user = Membership.GetUser(LoginPostbackData.Username);
                if (user != null)
                    //User exists
                    if (!user.IsApproved)
                        //Account Unapproved
                        model.Message = "Your account is not approved.";
                    else if (user.IsLockedOut)
                        //Account Locked
                        model.Message = "Your account is locked.";
                    else
                        //Invalid username or password
                        model.Message = "Invalid username or password.";
                else
            //model.Message = "Wrong credentials, try again " + isValid + " " + isUser + " " + Membership.Provider.Name + " " + LoginPostbackData.Username;
            return View("Index", model);
Current web.config provider settings:
<>membership defaultProvider="WindowsMembershipProvider" userIsOnlineTimeWindow="10">
      <>providers>
        <>clear />
        <>add name="MultiplexingMembershipProvider" type="EPiServer.Security.MultiplexingMembershipProvider, EPiServer" provider1="SqlServerMembershipProvider" provider2="WindowsMembershipProvider" />
        <>add name="WindowsMembershipProvider" type="EPiServer.Security.WindowsMembershipProvider, EPiServer" deletePrefix="BUILTIN\" />
        <>add name="SqlServerMembershipProvider" type="System.Web.Security.SqlMembershipProvider, System.Web,                 Version=4.0.0.0, Culture=neutral,               PublicKeyToken=b03f5f7f11d50a3a" connectionStringName="EPiServerDB" requiresQuestionAndAnswer="false" applicationName="EPiServerSample" requiresUniqueEmail="true" passwordFormat="Hashed" maxInvalidPasswordAttempts="5" minRequiredPasswordLength="7" minRequiredNonalphanumericCharacters="0" passwordAttemptWindow="10" passwordStrengthRegularExpression="" />
      providers>
    membership>
    <>roleManager enabled="true" defaultProvider="WindowsRoleProvider">
      <>providers>
        <>clear />
        <>add name="MultiplexingRoleProvider" type="EPiServer.Security.MultiplexingRoleProvider, EPiServer" provider1="SqlServerRoleProvider" provider2="WindowsRoleProvider" providerMap1="SqlServermembershipProvider" providerMap2="WindowsMembershipProvider" />
        <>add name="WindowsRoleProvider" applicationName="EPiServerSample" type="EPiServer.Security.WindowsRoleProvider, EPiServer" />
        <>add name="SqlServerRoleProvider" connectionStringName="EPiServerDB" applicationName="EPiServerSample" type="System.Web.Security.SqlRoleProvider, System.Web,                Version=4.0.0.0, Culture=neutral,                PublicKeyToken=b03f5f7f11d50a3a" />
      providers>
    roleManager>
Authentication method forms has been configured:
<>authentication mode="Forms">
What am I missing?
#184982
Nov 07, 2017 19:21
Minesh Shah (Netcel)
I assumend in 10.10 onwards the Membership functionality is provided via ASP_Identity so would guess you would need to use the following
var userProvider = ServiceLocator.Current.GetInstance<UIUserProvider>();
var user = userProvider.GetUser(userName);
#184999
Nov 08, 2017 11:30
Yep. That did it.
Any idea how I can change the default redirect location from the home page to a user assigned one? On successful signin it automatically redirects to the home page within the signin method preventing any other redirection action.
#185118
Nov 09, 2017 21:15
Looks like you're using the Membership classes which look at the <forms /> node in the web.config. You can set a default redirect URL by specifying the defaultUrl attribute on the <forms /> node. If you want a redirect URL based on Role/User, you probably will need to roll out your implementation of this - I'm not sure if there's an "OOTB" way of handling this requirement.
#185301
Nov 14, 2017 23:00
