EPiServer 10 Custom Dojo Gadget
Matthew Dunn
Matthew Dunn
OMVPCMP Administrator Certificationworkspace_premium
I am having trouble getting even the simplest Dojo gadget to work.
I've tried following the the guide on this page as well as various others: http://tedgustaf.com/blog/2014/6/create-an-episerver-widget-for-edit-mode/
What I need is an example of a Dojo front-end component that talks to a Controller to perform actions. The examples I have found are tied to Custom Properties, I need to have a gadget that is independent of Page Properties.
Is this possible?
Matt
#185354
Nov 16, 2017 11:06
Hi Matt
You can try use this as an example: https://github.com/davidknipe/VisitorGroupUsage. See this post for info on what it does: https://www.david-tec.com/2015/05/visitor-group-usage-viewer-for-episerver-8/
Its meant to be used for viewing visitor group usage. To make it "independent of page properties" drop the contextChanged handling from this file: https://github.com/davidknipe/VisitorGroupUsage/blob/master/VisitorGroupUsage/ClientResources/Scripts/visitorgroupusage/viewer.js.
Also to make it Episerver 10 compatible you need to not use the dot notation here: https://github.com/davidknipe/VisitorGroupUsage/blob/master/VisitorGroupUsage/UIComponents/VisitorGroupUsageViewer.cs. Read this post for information about the dot notation breaking change in Episerver 10: https://world.episerver.com/blogs/Ben-McKernan/Dates/2016/9/the-dot-notation-breaking-change/
David
#185356
Nov 16, 2017 12:35
Matthew Dunn
Thanks David. This working for me and is just what I need.
#185406
Nov 17, 2017 17:22
