Custom login page
So I am trying to create a custom login page instead of the EPi Server. Right now I have created a custom controller and model and page using this tutoiral
https://world.episerver.com/blogs/Daniel-Ovaska/Dates/2016/6/creating-a-custom-login-page/
The thing is when I type http://localhost:53067/LoginPage/Index in the browser window I get null for the currenPage in the below code
        public ActionResult Index(LoginPage currentPage, [FromUri]string ReturnUrl)
            /* Implementation of action. You can create your own view model class that you pass to the view or
             * you can pass the page type for simpler templates */
            var model = new LoginModel(currentPage);
            model.LoginPostbackData.ReturnUrl = ReturnUrl;
            return View(model);
Does anyone know what am I missing here?
#184563
Oct 31, 2017 13:02
You need to have a URL Epi can route to a page data object that you've added to the page tree.
If LoginPage is a Epi page type you need to use a URL of such a page.
Something like http://localhost:53067/my-cool-login-page/
#185411
Nov 17, 2017 17:48
I'm having the same problem. I'm a complete epi newbie except for an intensive boot camp training.
I've created a login page, viewmodel, controller and view according to this article
https://support.episerver.com/hc/en-us/articles/115002559451
Can you explain what you mean in the first sentence of your answer? How do I add my page to the page tree?  And how do I know what my page is called? Isn't is just login?
Here's the definition of my login page:
[ContentType(DisplayName = "LoginPage", GUID = "a1c77b97-95a6-447d-af9a-4b79b8770040", Description = "Login Page")]
[AvailableContentTypes(Availability = Availability.Specific,
IncludeOn = new[] { typeof(StartPage) },
ExcludeOn = new[] { typeof(ContainerPage), typeof(ProductPage), typeof(StandardPage), typeof(ISearchPage), typeof(LandingPage) })]
public class LoginPage : StandardPage
Thanks for your help.
#187904
Feb 06, 2018 4:42
  1. Go to Edit mode.
  2. Add a new page of type "Login Page" below your start page.
  3. Check which URL it got.
  4. Set that URL, something like /en/my-login-page/ as the default login page in web.config.
This setup has some drawbacks since you need to set public access for that page you added, it not you will cause a redirect loop. Use /util/login.aspx as a backdoor if this has happend.
#187905
Feb 06, 2018 7:41
Thanks for your help. That did the trick!
#187938
Feb 06, 2018 23:11
The above solution assumes that your login page has a specific name-in-url set. To avoid that dependency you can do something like this.
In Global.asax.cs:
protected override void RegisterRoutes(RouteCollection routes)
    // login page route
    routes.MapRoute("Login", "login", new { Controller = "SignIn", action = "Index" });
    base.RegisterRoutes(routes);
In SignInPageController:
public override ActionResult Index(SignInPage currentPage)
    // if you come here from custom route and are missing currentPage
    if (currentPage == null)
        currentPage = PageHelper.SiteSettingsPage.SignInPage.Get<SignInPage>();
    var model _signInPageFactory.Service.Create(currentPage);
    return View("Index", model);
However, you will need to have some kind of global site config where you reference your Login page so you can fetch it programatically.
#207569
Sep 25, 2019 11:38
