Upgrading from 9.5 to 10.3.2
Hi All,
I've been trying to upgrade one of cient's instances. Every single time I run finish upgrading the db the site is starting to throw the following exception:
System.Data.SqlClient.SqlException (0x80131904): Violation of PRIMARY KEY constraint 'PK_tblBigTable'. Cannot insert duplicate key in object 'dbo.tblBigTable'.
The statement has been terminated.
at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose)
at System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString, Boolean isInternal, Boolean forDescribeParameterEncryption)
at System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async, Int32 timeout, Task& task, Boolean asyncWrite, Boolean inRetry, SqlDataReader ds, Boolean describeParameterEncryptionRequest)
at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, TaskCompletionSource`1 completion, Int32 timeout, Task& task, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry)
at System.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(TaskCompletionSource`1 completion, String methodName, Boolean sendToPipe, Int32 timeout, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry)
at EPiServer.Data.Dynamic.Providers.Internal.DbDataStoreProvider.<>c__DisplayClass49_0.b__0()
at EPiServer.Data.Providers.Internal.SqlDatabaseHandler.<>c__DisplayClass29_0.b__0()
at EPiServer.Data.Providers.Internal.SqlDatabaseHandler.<>c__DisplayClass30_0`1.b__0()
or when I try to create a new page:
tem.Data.SqlClient.SqlException (0x80131904): Violation of PRIMARY KEY constraint 'PK_tblTree'. Cannot insert duplicate key in object 'dbo.tblTree'.
   at EPiServer.DataAccess.Internal.ContentSaveDB.CreateNewContent(IContent content, String currentUser)
   at EPiServer.DataAccess.Internal.ContentSaveDB.<>c__DisplayClass23_0.b__0()
Any ideas what could be an issue here?
Maciej
#174252
Jan 23, 2017 12:21
Can you paste SQL statement from SQL Profiler?
#174357
Jan 25, 2017 7:58
