How to fix empty dashboard?
I have an issue that after I added a gadget on the dashboard, initially it displayed the whole dashboard correctly but after I refreshed the page, dashboard became empty.
Link to the screenshot: http://imgur.com/a/QUTbU
The gadget I added is my custom gadget which has a controller in the same project. Here is the code how I defined it.
[Gadget(Title = "Sales statistics")]
public class SalesStatisticsGadgetController : Controller
    public ActionResult Index()
        // action code here
But there were also other gadgets. This happens on the server but locally where I have only this gadget, it works fine.
Episerver log is empty. No errors or warnings.
What could happen with it and how to fix it?
#174113
Edited, Jan 19, 2017 9:47
Any JS  error?
#174120
Jan 19, 2017 11:40
No, nothing in the Chrome Dev Tools console. Also, on the Network tab every request is 200.
#174130
Jan 19, 2017 12:16
I remember for adding new gadget needed to add this:
<module>
  <assemblies>
    <add assembly="GadgetAssembly" />
  </assemblies>
</module>
And without this, it was working sometimes.
#174134
Jan 19, 2017 12:24
I found out that when I locally add Order Gadget, I get the same behavior.
#174138
Jan 19, 2017 12:31
I see in the module.config in the root of my site that it has assembly added like:
<module>
  <assemblies>
    <add assembly="My.Web" />
  </assemblies>
</module>
As the gadget controller is in the My.Web project (same as the whole website).
After some testing, I found out that it doesn't like my gadget together with any of the Commerce gadgets. When I add my gadget and one of the Commerce gadgets - Order Gadget or Overview, then it stops working.
But it works fine when my gadget is added together with other gadgets. For example, BVN.404 redirect gadget.
#174142
Jan 19, 2017 13:11
Try to enable <clientResources debug="true" /> in the <episerver.framework> section. This will load the unminifed JS files and output more information in the console. Just make sure do not run this in production.
#174473
Jan 27, 2017 7:33
Thanks, Magnus, it did help to track the issue.
I found out that MenuPin caused that behavior. When I comment out it in my module.config, then everything works.
Now have to find out the way how to make it work with MenuPin enabled.
#174475
Jan 27, 2017 8:15
