Forms: Bad validation warning message for regular expressions
Sia
Sia
I'm using Form Container on Episerver 9. I've added a custom regex validation for a phone number field.
The validation, itself, works fine, but when the input is not a valid phonenumber, the error message is "Validation failed on "Phone Number" field: This field should be in "^\(?([0-9]{3})\)?[-. ]?([0-9]{3})[-. ]?([0-9]{4})$" format."
How can I show a simple "phone number is not valid" instead of that (without a hacky piece of js code).
Sia
#174576
Jan 30, 2017 17:35
Sia
Thanks Anish,
But that is a totally different path, which takes a lot of time. EpiServer Forms is already providing regex validation and I don't want to customize that, I just want to show the correct message for it. As you may know, ASP.NET data annotation syntax is like this:
[RegularExpression("^([a-zA-Z0-9 .&'-]+)$", ErrorMessage = "Invalid First Name")]
public string FirstName { get; set; }
This is a very common scenario for validation.
Thanks again,
Sia
#174652
Feb 01, 2017 13:54
Sia
One of my friends at work found the solution.
Create a Forms.xml inside \Resources\LanguageFiles and add this as the content:
<?xml version="1.0" encoding="utf-8" ?>
<languages>
  <language name="English" id="en">
    <episerver>
      <forms>
        <validators>
          <episerver.forms.implementation.validation.regularexpressionvalidator>
            <displayname>Regular expression</displayname>
            <message>This field should be in the correct format.</message>
          </episerver.forms.implementation.validation.regularexpressionvalidator>
        </validators>
      </forms>
    </episerver>
  </language>
</languages>
That's not a very ideal solution, because it's a general message for all regex, but still works!
#174661
Feb 01, 2017 17:31
Thanks for the above workaround, this has been an issue for us too.
#179432
Jun 12, 2017 14:22
