XForm form select button generated error
Hello,
On our site we use XForm for form implementations. We did some upgrades to EPIServer dll's and now we get an error we trying to select another form:
An object or column name is missing or empty. For SELECT INTO statements, verify each column has a name. For other statements, look for empty alias names. Aliases defined as "" or [] are not allowed. Change the alias to a valid name.
I tried to revert the DLLs back to the latest working version but the error remains.
Any thought?
#160646
Sep 30, 2016 18:47
Between which versions?
#160648
Sep 30, 2016 19:08
These are the dlls that were changed (and now reverted). Green is current installed version, red is newest version.
#160658
Oct 02, 2016 18:26
Don't forget the database schema can get updated through versions too so you could try rolling back to a back up version of the DB from before the upgrade.
#160659
Oct 02, 2016 18:40
Hi David,
Thanks for your comment. The DB updates are done manually and were not necessary in this upgrade.
#160661
Oct 02, 2016 19:06
Some seemingly random uninstalls / installs of EPIServer dll's fixed my problems. Not a very satisfying solution.
#160707
Edited, Oct 04, 2016 9:31
Probably a dll with wrong version somewhere then...
#160709
Oct 04, 2016 10:05
