Restrict access to a language
Hello,
Is there an easy way to restrict access to a language e.g. www.example.com/en-za, if anyone goes to that site that isnt logged in, they will see just a login screen?
I have tried adding a location for it but it appears not to work
Regards
Ben
#160136
Sep 28, 2016 10:49
Nope. Not an easy way that I know of at least if you use language versions of the same page.
Unless you have it in a separate branch in the tree structure...then it's easy.
#160531
Sep 28, 2016 11:04
Hi, you have access settings per language in admin mode, you should be able to use that, have you tried?
http://prntscr.com/cnc0lx
BR,
Marija
#160539
Edited, Sep 28, 2016 13:58
Ah I missed that one!
#160540
Sep 28, 2016 14:02
Doesn't that just cater for Adding or Editing landuage assets?, can that be used to lock out anonymous users from viewing that language?
#160548
Sep 28, 2016 14:47
It should be that if you remove Anonymous from a language, users cannot access the entire language. I haven't been in need for the feature, so I think you'll have to test it, it should be pretty easy.
#160556
Sep 28, 2016 14:56
Sadly i have tried it and it only caters for change permissions not viewing the language anonymously, oh well thank you for your help!
#160581
Sep 29, 2016 9:12
Guess it makes sense not to have access rights on language level on content. A lot of extra complexity with few real benefits. Guess you'll have to settle with hiding the language from the user...
#160583
Sep 29, 2016 9:38
