How to Capture Custom Scheduled Job is Turned on or Turned off in Episerver CMS
Hi Guys,
We have a Custom Scheduled Job in Episerver 7.5 CMS under Scheduled Jobs, When the job is on, it runs the functionality what we require and job is off it doesnt process any thing.
Now the Requirement is, when the custom job is off in CMS. Can we capture the scheduled job is off or on from CMS Tables anywhere. if so, how do we call CMS tables in c#.
#155410
Sep 16, 2016 8:41
You can use the ScheduledJobRepository to get some information about the jobs.
using EPiServer.DataAbstraction;
var jobRepository = ServiceLocator.Current.GetInstance<ScheduledJobRepository>();
var isEnabled = jobRepository.List()
                .First(job => job.Name.Contains("Notification"))
                .IsEnabled;
Above I list all jobs and grabs the first that contains the name Notification. You should be able to find yours there as well and check status.
Hope that helps!
#155417
Edited, Sep 16, 2016 10:55
Hi Arjun
There is a plug in that enables you to see the status of scheduled jobs:
http://blog.tech-fellow.net/2013/10/17/overview-your-episerver-scheduled-jobs-interactively/
David
#155430
Sep 16, 2016 15:57
+1 for David, if you are looking for table on db. Look in db with name like tblSchedule (although it is not recommended ) :)
#155442
Sep 16, 2016 21:36
